just got done putting my passing lites on and wiring in the relay. been through alot of threads, was just wondering how big a fuse should be used in the line from the battery?:confused24::stirthepot:
As to what size fuse it should have.
The formula to find out how many amps you will use is, P ÷ E = I .
P is power of the lights in watts. (Remember there are 2 lights)
E is voltage. 12V
I is the Amps that will be drawn.
Use the next higher standard size fuse.
