octoberboy Posted March 10, 2013 #1 Posted March 10, 2013 Need a little guidance with how to remove my chrome covers (engine, crankcase, etc). They are are all attached with unslotted screws (see picture). I assume there is a special tool I need to get? Some of the screws, like for the engine covers, have almost no clearance around them. Afraid if I don't do things the proper way I could make a much bigger problem for myself.
Carbon_One Posted March 10, 2013 #3 Posted March 10, 2013 You need what is called hex bit sockets - http://www.craftsman.com/shc/s/search_10155_12602?keyword=metric+hex+bits and/or Allen wrenches - http://www.craftsman.com/craftsman-26-pc-standard-and-metric-ball-end/p-00946274000P?prdNo=28&blockNo=28&blockType=G28 Larry
Wade 2000 Posted March 10, 2013 #4 Posted March 10, 2013 There are caps on the hex heads, pop them off to expose the hex slot
playboy Posted March 10, 2013 #5 Posted March 10, 2013 There are caps on the hex heads, pop them off to expose the hex slot :sign yeah that:
octoberboy Posted March 10, 2013 Author #6 Posted March 10, 2013 I was a bit confused because there was no place to put the hex head. I took a different close up picture to show you as an example. When I looked at that I realized there is a cap over the hex slot. All is good in the world again. At least for now. Thanks Larry.
djh3 Posted March 10, 2013 #7 Posted March 10, 2013 I just looked up today for another thread. Autozone has the allen socket set in 3/8 drive for $15. 3mm (fits fairing screws) 4mm, 5mm 6mm 8mm 10mm. That should just about cover anything on the bike. Ocasionaly you find the standard L type works better.
steamer Posted March 10, 2013 #8 Posted March 10, 2013 Didn't I tell you about all those bolt caps:confused24: Just about every bolt on your bike have caps on them.
playboy Posted March 11, 2013 #10 Posted March 11, 2013 Aren't they called security caps? NO NO NO they are safety caps there chrome aren't they:stirthepot:
dacheedah Posted March 11, 2013 #11 Posted March 11, 2013 I would use allens in a 1/2 or 3/8 drive and to replace them use a torque wrench to drive them.
