Hello again! Spring can't come soon enough! About those antenna on the RSV . . . are they permanent fixtures or can they easily be removed and stored when I will not want to use them . . . like when I am riding around locally? Would appreciate knowing more about those things! Thanks!!
You can remove them, but they are not intended to be removed. The mounts would still be in place, the cable would need to be tied up.
Your radio nor CB would work. You risk breaking some items that are not cheap to fix/replace.
My suggestion is to leave them alone.
RR
