What do you torque them down to. I cant seem to find it anywhere in my service book. It tells you to torque the clamps to 2.2lb I think. But what lb for the two bolts that hold down the boot itself?
I don't know the torque spec for sure, but can tell you that the spec for a 6mm bolt into aluminum is typically 7.2 ft-lbs. In other words, just snug. They are good candidates for anti-seize compound too.
I guess it is one of those things ,like the fuel air mix screw, that you are not suppose to mess with. I trll you what, when I went to take them off...I had to really turn hard to break the bolts free. Maybe they just set in but it was way more then 7lb it felt like. I had to clamp my hex wrench with vgrips...lol.
Which is why anti-seize is a good idea on them. A few more years and they'd likely have just broken off.
