pietermoore Posted March 2, 2013 #1 Posted March 2, 2013 anyone have the J tool for changing out shims on the xvz? my xvz is torn down and I'm tired of trying to make a homemade one work:rotf:. borrow or buy would be fine. Also, I will have a supply of the more popular shim sizes when I'm done if anyone needs some.
Flyinfool Posted March 2, 2013 #2 Posted March 2, 2013 You mean this tool? http://www.venturerider.org/classifieds/showproduct.php?product=4475&title=valve-shim-tool&cat=10
abusive throttle cranker Posted March 2, 2013 #3 Posted March 2, 2013 I just got a reply from Bike Bandit to my question about shim prices. Their site says $15.95 but a piece count of zero. You betcha- $15.95 PER SHIM!!! Their excuse? Its OEM and not available as an aftermarket item! I'm still waiting a reply from Chaparral Motorsports. Their listing says $11.30 and a piece count of 16! I asked if I can mix sizes in that 16 count.
slowrollwv Posted March 3, 2013 #4 Posted March 3, 2013 I have a shim tool I can lend. All I ask is that you return it when done. Send me your address in a PM and I will get it to you
dingy Posted March 3, 2013 #5 Posted March 3, 2013 SemiRetired said: I just got a reply from Bike Bandit to my question about shim prices. Their site says $15.95 but a piece count of zero. You betcha- $15.95 PER SHIM!!! Their excuse? Its OEM and not available as an aftermarket item! I'm still waiting a reply from Chaparral Motorsports. Their listing says $11.30 and a piece count of 16! I asked if I can mix sizes in that 16 count. The 16 count means there are 16 of these in the motor. The shims are somewhat unique in that you would not need 16 of the same, but that is the way many parts suppliers software works. Picture is from partzilla.com site. Above 1st red block is notation 'Price is for one part' Gary
abusive throttle cranker Posted March 3, 2013 #6 Posted March 3, 2013 Partzilla eh? $8.68 is the best price I've seen. PartShark wants $10.99.
Flyinfool Posted March 4, 2013 #8 Posted March 4, 2013 dacheedah said: Jeff, were you workin on making shims?? Yup See post #2 for the tool Still working on being able to modify thickness
djh3 Posted March 4, 2013 #9 Posted March 4, 2013 When I had my FJ1200 motor in the Legends car I was getting shims from I think Mr Cycle. Seems to me at that time a couple years ago it was around $5-6 ea. Luckely I have a bag full of shims different sizes now. But I have a real over abundance of big shims, like 300 range. I need to see if I can sell the FJ valve tool. I gave like $40+ for it. Jeff: you heard anything about the one Bob was working on last year? Last I had heard he had to knock off on the free work (the valve tool) as he had paying jobs.
dacheedah Posted March 4, 2013 #10 Posted March 4, 2013 I found my xj valve tool, haven;t had it in about 15 years
djh3 Posted March 4, 2013 #11 Posted March 4, 2013 New FJ tools go for around $55 on e-bay. By the way here is a link to some valve shims. Unless you use them to pund on you cant hardly hurt them so used is an option in my book. Some have a selection some individual. Maybe someone will chime in but I dont think you need very many above 280.
pprince Posted March 4, 2013 #12 Posted March 4, 2013 Can't you just flip them over so the wear is now on the other side?
Flyinfool Posted March 4, 2013 #13 Posted March 4, 2013 I do not think it the shims that are wearing. It is other components in the valve system that are wearing and you have to change the shims to get all of the clearances back to where they should be. On my high mileage parts motor all of the shims still look brand new.
RandyR Posted March 4, 2013 #14 Posted March 4, 2013 I have a kit with shim tool and assorted shims. You can borrow it if you exchange the shims with ones you take out. Any used in the range of 2.55-2.70 will need to be replaced with similar size as those are the ones most commonly needed and in short supply in the kit. Also Earl skydoc sells the needed cover gaskets and will lend you a tool and a shim kit if you buy gaskets from him. Member MiCarl sells shims and the tool. http://www.venturerider.org/forum/forumdisplay.php?f=210
djh3 Posted March 4, 2013 #15 Posted March 4, 2013 The way it was explained to me on the FJ motor and I have to assume its basicly the same on all the shim adjusted motors. As the engine runs the cam trys to push the valve out of the head, the spring trys to pull it back thru the head. Thus the clearences get less. So if you have say a 300 shim in it as the valve get pulled up your clearence gets smaller and you need to go to say a .275 shim or whatever the chart says.
RandyR Posted March 4, 2013 #16 Posted March 4, 2013 djh3 said: The way it was explained to me on the FJ motor and I have to assume its basicly the same on all the shim adjusted motors. As the engine runs the cam trys to push the valve out of the head, the spring trys to pull it back thru the head. Thus the clearences get less. So if you have say a 300 shim in it as the valve get pulled up your clearence gets smaller and you need to go to say a .275 shim or whatever the chart says. The reason the clearance gets less is that as the valve slams back into the head, it wears the face of the head slightly.
djh3 Posted March 4, 2013 #17 Posted March 4, 2013 Other bikes use the same shims, not just Yamaha. Honda cbr 650 yamaha fj 1100-1200 xjr 1300 they are 25mm shims. So sometimes you can find them on e-bay listed for a different bike for less.
