OldGazer Posted February 27, 2013 #1 Posted February 27, 2013 I'm finishing up my winter maintenance and I plan to put a set of Road King mufflers on. I have the mufflers, but I need to know what is the best way to mount them. I know about needing to make a transition piece, but what I need are some close up pictures of the final mounting arrangements that Y'All have used. I did a search an all I found were some long distance shots that did not show any mounting brackets or adapters. If you want you can hit me on yahoo. My screen and e-mail make is red03sporty (that is a zero, not the letter 'O') Thanks.
Condor Posted February 27, 2013 #2 Posted February 27, 2013 OldGazer said: I'm finishing up my winter maintenance and I plan to put a set of Road King mufflers on. I have the mufflers, but I need to know what is the best way to mount them. I know about needing to make a transition piece, but what I need are some close up pictures of the final mounting arrangements that Y'All have used. I did a search an all I found were some long distance shots that did not show any mounting brackets or adapters. If you want you can hit me on yahoo. My screen and e-mail make is red03sporty (that is a zero, not the letter 'O') Thanks. On the first gens you will need to have an adapter pipe made from the muffler to the collector. In the past most members have gone to their local muffler shop and had them made. Maybe having them made up and then get them chomed would be kinda cool....??
OldGazer Posted February 28, 2013 Author #3 Posted February 28, 2013 Condor said: On the first gens you will need to have an adapter pipe made from the muffler to the collector. In the past most members have gone to their local muffler shop and had them made. Maybe having them made up and then get them chomed would be kinda cool....?? I've got that part covered. Having the transition pipe chromed is a real waste of money, 'cause the heat from the exhaust is gonna turn in blue any way. If I want bling I'll find a chrome heat shield... What I really need are close up pictures of how the muffler is attached to the saddle bag support.
Condor Posted February 28, 2013 #4 Posted February 28, 2013 OldGazer said: I've got that part covered. Having the transition pipe chromed is a real waste of money, 'cause the heat from the exhaust is gonna turn in blue any way. If I want bling I'll find a chrome heat shield... What I really need are close up pictures of how the muffler is attached to the saddle bag support. Generally it's the header pipes that blue out from the heat. I can't remember seeing anything that far back being effected. I think Carbon One was making a set of brackets to mount the RK's on the RSV's. Give him a shout.. If he isn't, maybe he knows which member did??....
OldGazer Posted February 28, 2013 Author #5 Posted February 28, 2013 I've seen some brackets on evilBay, but the seller has some disclaimer about not being able to ship due to an illness or some such thing. Still, having pictures is what I require so I can see what is needed BEFORE I spend any money.
Condor Posted February 28, 2013 #6 Posted February 28, 2013 OldGazer said: I've seen some brackets on evilBay, but the seller has some disclaimer about not being able to ship due to an illness or some such thing. Still, having pictures is what I require so I can see what is needed BEFORE I spend any money. OK, here ya go. Found this after doing a search on the board. Second post down. http://www.venturerider.org/forum/showthread.php?t=48441&highlight=harley+muffler+bracket
OldGazer Posted March 2, 2013 Author #7 Posted March 2, 2013 Thanks for the link. I did some digging and I'm going to check out some flex pipe and some pipe hangers at AutoZone. If these work out I may be able to come up with a "better" way to do this... I'll keep ya posted.
djh3 Posted March 3, 2013 #8 Posted March 3, 2013 The only issue I see with the hanger on that link is that wiht only one bolt on the forward mounting point it wouldnt seem to me it is really supporinting any weight. To lighten up the load as far as the overall weight you could use square alum tubing also, probably 1" angle of your choice would work too. Alum if you polish it up looks pretty spiffy also almost chrome. I did see a thread on these boards where a fellow used just the ole glass pack (cherry bomb type)mufflers and it sounded pretty dang good.
Daitan Posted March 3, 2013 #9 Posted March 3, 2013 (edited) I just did the same exact mod to my '84. I actually mounted a bracket coming down from the bottom rail of the side bag (behind the bag) and then over like a 'L" shape bracket. But for the adapter pipes, went to an auto parts store, got the 1 1/2" galvanized pipe that is 12" long, it has a flared end that is abt 1 3/4 and the other end is 1 1/2. If you get the couplers that fit over both ends of the pipe, you won't need any gasket. And what I also did before final mounting. I got some engine paint at lowes, 2000 Degree paint, and painted them, then followed the instructions to bake them. Flat black looks real nice, before the chrome slip-ons. Edited March 7, 2013 by Daitan adding pics
jasonm. Posted March 3, 2013 #10 Posted March 3, 2013 I agree with the last 2 posts. Having the mount to the bike @footpeg bracket will put twisting on the "16 degree" bent pipe. Unless there was an unseen "stop" in the home made assy. that we could not see. Vertical (straight up)_to the frame support is always best like the stock way our bikes were made. To the saddlebag mounts/guards seemd doable. Take your time.
OldGazer Posted March 9, 2013 Author #12 Posted March 9, 2013 The flex pipe idea was a bust, so I'm back to square 1.
Daitan Posted March 10, 2013 #13 Posted March 10, 2013 flex pipe??? Don't know what got you thinking of that. But, did you get far before it went out on ya?
OldGazer Posted April 23, 2013 Author #14 Posted April 23, 2013 The flex pipe was all wrong. You can put it over the collector box outlet, but you cannot get it to seal inside of a H-D muffler inlet... But, here is what I did: The pics show a hanger attached to the muffler mounting bolt. An H-D muffler clamp is welded to the hanger. The transition pipe is custom bent. Complete install cost me a C note...
SilvrT Posted April 23, 2013 #15 Posted April 23, 2013 This mod will not help you catch up to a 2nd gen yanno ... (somebody had to say it)
OldGazer Posted April 24, 2013 Author #16 Posted April 24, 2013 SilvrT said: This mod will not help you catch up to a 2nd gen yanno ... (somebody had to say it) I don't feel the need to catch up to anyone. If you pass me on the super slab the ticket is all yours...
Ben Rollins Posted October 29, 2014 #17 Posted October 29, 2014 Can anyone post a sound bite(video) of a first gen with RK or any harley pipes? Really curious of the sound.
Ben Rollins Posted November 8, 2014 #18 Posted November 8, 2014 No one has sound video of first gen with pipes?
Rosie1965 Posted November 8, 2014 #19 Posted November 8, 2014 Ben, to get the best sound would be difficult since the rear is getting squirrlly and the front is getting light when it sounds the best.
Ben Rollins Posted November 8, 2014 #20 Posted November 8, 2014 LOL, never thought of it that way. Guess I will just have to wait until I get mine put on.
Rosie1965 Posted November 8, 2014 #21 Posted November 8, 2014 You will have to forgive me for not being too tech savvy but I put up a you tube video for you. 1990 Venture Royale mods:
Rosie1965 Posted November 8, 2014 #22 Posted November 8, 2014 The sound quality on this video is pretty good but depends a lot on what you play it back with. My android speakers don't do it justice, but hooked to my sub sounds good.
Ben Rollins Posted November 8, 2014 #23 Posted November 8, 2014 Very nice sound, Thank you for the post. Can't wait to get them on my 83.
Ben Rollins Posted November 21, 2014 #24 Posted November 21, 2014 So I see where a 16 degree angle is needed, Is this the same for a 83 venture? I would think the 90s down to 83s would be the same,am I right or wrong? I plan on having some pipe bent soon so I can start laying it out.
Rosie1965 Posted November 22, 2014 #25 Posted November 22, 2014 I don't know for sure but I think they are the same.
