usedcyclesales Posted February 25, 2013 #1 Posted February 25, 2013 I've been using Marvel mystery oil and Sea Foam for such a long time . Well, I used both to try and clean my carbs out , I had an idle issue where it was going up and down and when i rode it for a while it would stay real high and if I turned it down to where it sounded normal the next day when you started it it wouldn't idle without the choke out then you'd ride it and the same thing the idle would shoot right up. So I tried techron I did the same thing as I did with the others .I disconnected the fuel line put a funnel in it and flooded the carbs with it and let it sit over night. Well a NIGHT and DAY difference it idles fine the throttle response is normal and sounds great. This stuff just made me a believer also it was $6.97 enough for 20 gallons of gas. The other thind Sea Fom and Marvel made the engine harder to start and smoked a hell of a lot. The techron didn't smoke at all and started right up.
playboy Posted February 26, 2013 #2 Posted February 26, 2013 :no-no-no: thats on the border of being blasphemy around here. I hope the clutch whine doesn't rear it's ugly head now.
Miles Posted February 26, 2013 #3 Posted February 26, 2013 You see...unlike those that drink Seafoam for breakfast with their eggs and bacon, I am a fervent believer in using Chevron Techron, and I have cases of the stuff on the shelves in my shop. I am enough that I do use Marvel Mystery Oil...when the time is right, and the need calls for it. I believe in MMO, and have used it for more than 40 years. And, on the rare occassion that a politician in Washington DC actually tells the truth about anything in life, I do use Seafoam in those rare moments. BUT...Seafoam, contrary to what some of these drug-addicted Seafoam users think...is NOT to be used as a daily cocktail for cleaning fuel or oil systems. For what the rest of you use Seafoam for...I have been using Chevron Techron for, for the past 25 + years. In my shop, you will find it well stocked on Techron, and a one gallon red plastic bottle of Marvel Mystery Oil. It makes me cringe everytime I read another post about some rider wanting to use Seafoam as a daily enema, to clean something out. It has its' time and place in the mechanical world, but it is not the fix-all for everything that ails you. Use Chevron Techron, as a quarterly fuel system cleaner, and as a stabilizer for the winter time storage, and your machines will run for a long time.
Black wing Posted February 26, 2013 #5 Posted February 26, 2013 ive been a sea-foam guy for years. though i would love to see what that techron can do
mraf Posted February 26, 2013 #6 Posted February 26, 2013 I had a sticking float on my Venture. So I did the straight Sea-foam soak for two days . Drained it into a clear glass container. Then did a straight Techron soak for two days right after the seafoam soak. I caught the Techron in a clear glass container. There was a definite darker color to the Techron container. Glean what you want from this info. The float hasn't been a problem since. One of my friends was a Ford mechanic at a local dealership and has told me that there was a Ford bulletin on using Techron to clean a sticking fuel gauge on their cars. He has used it to fix alot of them. Sure beats pulling the tank to fix. I use it occasionally in the bike since. It is a little cheaper than sea-foam. Supposedly Shell gasoline has it in all grades of their gas.
Yammer Dan Posted February 26, 2013 #7 Posted February 26, 2013 I used Techron a long time ago. Need to revisit it. As I have said Sea-Foam is great at times. I do think using it regularly keeps a lot of problems away. But it is not the only cleaner I use mainly because it has gotten so costly. My shop has Sea-Foam, BerryMan's Chem Tech, Marvel Mystery Oil, Star Tron and probally a couple others maybe some old Techron in there. My point has always been use as needed. I use Sea-Foam several times a year because I think it prevents problems. Use what ever you feel safe using. Some cleaners will ruin your carbs.
djh3 Posted February 26, 2013 #8 Posted February 26, 2013 Need to try some on my small engines like generator and pressure washer that dont get used a whole lot. I try to run the carb dry before I put them away. but 8 out of 10 times I end up pulling the carb apart before I can get them to run. As Phoo says "oh bother"
Mike G in SC Posted February 26, 2013 #9 Posted February 26, 2013 Yamaha Ring Free (expensive stuff) is basically concentrated Techron,,, I do believe. Supposed to have same main ingredient. Used to use it for stick valve on my Road Star.
midnightventure Posted February 26, 2013 #10 Posted February 26, 2013 I am also a Techron believer. I have a 95 Trans Am which sits for weeks at a time in a garage. Occasionally it gets to running rough when I first start it. Run a tank of gas with techron in it through and it clears right up.
reddevilmedic Posted February 26, 2013 #11 Posted February 26, 2013 midnightventure said: I am also a Techron believer. I have a 95 Trans Am which sits for weeks at a time in a garage. Occasionally it gets to running rough when I first start it. Run a tank of gas with techron in it through and it clears right up. and with whatevers left, he can wash his mullet!! :rotf:
dacheedah Posted February 26, 2013 #12 Posted February 26, 2013 U know this is a tough crowd, but what kind of blinker fluid do U use
PBJ Posted February 26, 2013 #13 Posted February 26, 2013 dacheedah said: U know this is a tough crowd, but what kind of blinker fluid do U use I use Tech foan mystery lube blinker oil in my bikes! Wow! this is a good thread. seeing as all my vehicles are old, 84 Honda Sabre v65, 84 Ford Mustang GT Turbo and 86 Yamaha Venture Royale anything that keeps them running "younger" is food to me going to buy some and try it this season. The Mustang sits alot and seems to have a sticky valve, and the Yamaha needed a couple of tank fulls of sea foam to really get it running right last year. But now it runs like a champ. But this Techron stuff sounds good and i'm going to try it.
Pretty Hips McGee Posted February 26, 2013 #14 Posted February 26, 2013 I'm usually only a reader of this forum to learn about the Venture and as such I usually don't have much to say, but If you're more interested in gas stabilization than a detergent take a look at Startron. It's used for boats and does a wonderful job. Pretty cost effective also which is important when the tank holds 300 gallons. http://mystarbrite.com/startron/
midnightventure Posted February 26, 2013 #15 Posted February 26, 2013 (edited) reddevilmedic said: and with whatevers left, he can wash his mullet!! :rotf: What a jerk. What you just said is why I think about not paying my 12 dollars next time. I knew somebody like you once. His father was also his grandfather. Edited February 26, 2013 by midnightventure
reddevilmedic Posted February 26, 2013 #16 Posted February 26, 2013 midnightventure said: What a jerk. What you just said is why I think about not paying my 12 dollars next time. I knew somebody like you once. His father was also his grandfather. you knew my dad!??? im just kiddin with ya....geez......
midnightventure Posted February 26, 2013 #17 Posted February 26, 2013 I wasn't kidding. There was an older guy when I was a kid that would just say the stupidist things out of the blue. I am 57 now and was talking to his younger cousin the other day and found out that his father was also his grandfather. Explained a lot. You don't know me. If we were acquainted and had kidded around with each other I could understand something like that maybe. As it is your lucky I wasn't standing by you when I read that.
reddevilmedic Posted February 27, 2013 #18 Posted February 27, 2013 midnightventure said: I wasn't kidding. There was an older guy when I was a kid that would just say the stupidist things out of the blue. I am 57 now and was talking to his younger cousin the other day and found out that his father was also his grandfather. Explained a lot. You don't know me. If we were acquainted and had kidded around with each other I could understand something like that maybe. As it is your lucky I wasn't standing by you when I read that. scary.....oooohhhhh. you dont know me either:080402gudl_prv:
jfoster Posted February 27, 2013 #19 Posted February 27, 2013 Serious question....no bs'n! I get pure gas with no ethanol and no additives (cheap gas by old standards). I've been treating it with either 3/4 of an oz with B12 or 1 oz of Seafoam per gallon. Now Techron is more expensive than Seafoam. Now would one recommend skipping Seafoam and B12 for Techron every 3k miles? Thoughts!
Yammer Dan Posted February 27, 2013 #20 Posted February 27, 2013 If I'm having no problems I only use a few ounces about every 4th of 5th tank. Or about once a month.
Miles Posted February 27, 2013 #21 Posted February 27, 2013 jfoster said: Serious question....no bs'n! I get pure gas with no ethanol and no additives (cheap gas by old standards). I've been treating it with either 3/4 of an oz with B12 or 1 oz of Seafoam per gallon. Now Techron is more expensive than Seafoam. Now would one recommend skipping Seafoam and B12 for Techron every 3k miles? Thoughts! The answer to your question is: Yes. The B12 is good/okay. But the Techron is much better than the Seafoam. Allow me to use an analogy: Using Techron periodically is like using a small ball-peen hammer to carefully smooth out the door dings in your car. Using Seafoam is like using a 10 pound sledge hammer to bend the frame back into place, when the insurance company has totaled your car, and you buy back the salvage. Every product has its' place, and the correct time to use it. I do think there is a place and a time to use Seafoam. My concern is that I see a lot of posts on this forum from people that are using Seafoam as a regular dietary supplement to their fuel system, and that is not what it is designed for. (no...it is not !) The Berryman's B-12, and the Chevron Techron are better suited for dietary supplement to a fuel system. Given the choice, I would use the Techron. The Berryman's B-12 gets placed in between the Techron and the Seafoam, as far as needs or severity.
PBJ Posted February 27, 2013 #22 Posted February 27, 2013 Went out and bought me some of that techron and waiting for spring to add it. I already have the tanks topped off and Seafoam added for the winter storage.
Yammer Dan Posted February 28, 2013 #23 Posted February 28, 2013 Use whatever you want. I use what works.
Yammer Dan Posted February 28, 2013 #24 Posted February 28, 2013 Miles said: The answer to your question is: Yes. The B12 is good/okay. But the Techron is much better than the Seafoam. Allow me to use an analogy: Using Techron periodically is like using a small ball-peen hammer to carefully smooth out the door dings in your car. Using Seafoam is like using a 10 pound sledge hammer to bend the frame back into place, when the insurance company has totaled your car, and you buy back the salvage. Every product has its' place, and the correct time to use it. I do think there is a place and a time to use Seafoam. My concern is that I see a lot of posts on this forum from people that are using Seafoam as a regular dietary supplement to their fuel system, and that is not what it is designed for. (no...it is not !) The Berryman's B-12, and the Chevron Techron are better suited for dietary supplement to a fuel system. Given the choice, I would use the Techron. The Berryman's B-12 gets placed in between the Techron and the Seafoam, as far as needs or severity. And you will be rebuilding those 2nd Gen carbs before I rebuild mine.
Freebird Posted February 28, 2013 #25 Posted February 28, 2013 (edited) Well, my opinion is that none of these products are needed as a gas additive at every fill up. The gas today does leave something to be desired but if you are riding your bike enough to keep the gas fresh, today's has has plenty of additives, detergents, etc. to keep your fuel system clean. The problems occur when your bikes sits for a long enough time that the gas gets old. If that is the case, then some type of stabilizer will prevent most problems and you will not get to the point of needing to actually soak the carbs due to them being gummed up. My bike is now 14 years old. I have never used additives on a per tank basis. I have used various products when I knew the bike would be sitting, for example over the winter. I use one can to a full tank of gas before pretty much putting the bike away for the winter. I usually add one more can sometime in early spring or summer just to make sure anything that MAY have started gumming up is cleaned out and that is it. Two cans a year. Now for the past 5 years or so, the product that I've used has indeed been Seafoam and it has worked just fine. I am sure the Techron work OK too though. KNOCK ON WOOD...in 14 years, I've not needed any carb maintenance, have not had a float stick, etc. I did pull my carbs a couple of years ago to check and set the float levels and they looked great on the inside. Edited February 28, 2013 by Freebird
