DEPUTY 1216 Posted February 22, 2013 Share #1 Posted February 22, 2013 I want to put a 21'' tire/wheel on the front of my venture. Do they make a kit? Link to comment Share on other sites More sharing options...
jfoster Posted February 22, 2013 Share #2 Posted February 22, 2013 Awhile back some posted putting a stratoliner wheel on the front and it looked sharp. Don't remember what he had to do to make the swap. Link to comment Share on other sites More sharing options...
Miles Posted February 23, 2013 Share #3 Posted February 23, 2013 Awhile back some posted putting a stratoliner wheel on the front and it looked sharp. Don't remember what he had to do to make the swap. An 18" wheel from a Stratoliner is an exact drop-in fit for the front of a '05-'09 Royal Star or Venture. I cannot say with 100 % certainty that it will also fit a 2001 model, but, I believe it will. I have personally measured every nano of the stock wheel, and the stratoliner wheel, and it is truly an exact drop-in...uses the same wheel bearings, the same wheel seals, the RSV brake rotors bolt right up to the Stratoliner wheel. I am not aware of anyone that makes a 21" wheel that easily fits the front of a RS or Venture, but...you can check around. Question would be...WHY ? Given the weight of a RS or Venture...I do not think it would be wise to hang that much weight on the rim and tire of a 21". And...Deputy 1216, do you have a 2001 Venture, or a Royal Star ??? Link to comment Share on other sites More sharing options...
Pegasus1300 Posted February 23, 2013 Share #4 Posted February 23, 2013 I would think that PM would be willing to make one for you in any of their styles but you'll choke on the price. PM= Precision Machine. Link to comment Share on other sites More sharing options...
slowrollwv Posted February 23, 2013 Share #5 Posted February 23, 2013 An 18" wheel from a Stratoliner is an exact drop-in fit for the front of a '05-'09 Royal Star or Venture. I cannot say with 100 % certainty that it will also fit a 2001 model, but, I believe it will. I have personally measured every nano of the stock wheel, and the stratoliner wheel, and it is truly an exact drop-in...uses the same wheel bearings, the same wheel seals, the RSV brake rotors bolt right up to the Stratoliner wheel. I am not aware of anyone that makes a 21" wheel that easily fits the front of a RS or Venture, but...you can check around. Question would be...WHY ? Given the weight of a RS or Venture...I do not think it would be wise to hang that much weight on the rim and tire of a 21". And...Deputy 1216, do you have a 2001 Venture, or a Royal Star ??? The wheel may be a direct drop in and the rotors may bolt to a Strat wheel but I would look awful close at the clearance of the fender before I would try to fit any other wheel on a 99 to 2013 Venture. I don't see enough room for anything in there. Link to comment Share on other sites More sharing options...
Miles Posted February 23, 2013 Share #6 Posted February 23, 2013 The wheel may be a direct drop in and the rotors may bolt to a Strat wheel but I would look awful close at the clearance of the fender before I would try to fit any other wheel on a 99 to 2013 Venture. I don't see enough room for anything in there. slowrollwv, you make a good point, and...to answer your inquiry...I have in fact measured it ALL, and the 18" tire mounted on a Stratoliner 18" wheel, will in fact fit perfectly inside and under the stock fender of a '99 -'13 Venture or a '05 - '09 RSTD. The difference between a stock wheel and tire from a modern Venture/RSTD compared to a wheel and tire from a Stratoliner is less than a 1/4 " in overall height, and it is narrower than the stock tire. I appreciate your concern, and it makes sense to check these things out, however...I am not one to make errors on measurements, and If I say it will fit, then by golly...it will fit, just as Big Tom will eat Ice Cream today. Link to comment Share on other sites More sharing options...
