awsmsrv Posted February 18, 2013 Posted February 18, 2013 It would help to know what bike you're referring to, how much weight you're carrying, etc.
Gary N. Posted February 19, 2013 Posted February 19, 2013 7 lbs. max front and 55 lbs. max rear for 2nd gen.
Squidley Posted February 19, 2013 Posted February 19, 2013 Hey Brad (nice name) I see you have a '99, max in the front is 7psi max in the rear is 55psi. Use a hand pump to inflate the shocks, especially the front ones as you can blow the seals out pretty easily. I'm 280 lbs, on my G2's I would run 5 lbs in the front. Solo riding, 35 to 40 psi in the rear, 2 up 45lbs or so. Loaded up completely max it out at 55lbs....
