kkent66 Posted February 7, 2013 #1 Posted February 7, 2013 I have a 2006 RSV with 50k. Over the past two years I have been getting brave, reading on this forum a lot, and have been doing my own work on my bike. Last year I had my bike to the shop one time for a valve adjustment and had my spark plugs replaced. I have been doing a lot of work on my bike the last two weeks and ready to change my spark plugs and can't find my wrench. What size/type of socket do I need to change my plugs?
Marcarl Posted February 7, 2013 #2 Posted February 7, 2013 (edited) I have a 2006 RSV with 50k. Over the past two years I have been getting brave, reading on this forum a lot, and have been doing my own work on my bike. Last year I had my bike to the shop one time for a valve adjustment and had my spark plugs replaced. I have been doing a lot of work on my bike the last two weeks and ready to change my spark plugs and can't find my wrench. What size/type of socket do I need to change my plugs? 18mm thin walled socket. Crack all the plugs loose, blow out the recess with lots of air, and then remove plug. You might find that a super short extension would be a handy thing to have as well, I just use a u-joint. Edited February 7, 2013 by Marcarl
Freebird Posted February 7, 2013 #3 Posted February 7, 2013 I agree with Marcarl but would also question if you even need to change the plugs. You said that they were changed last year. How many miles since then? I should also point out, just in case there is any confusion, he made a typo...don't go out looking for a tin walled socket, he meant to type THIN walled socket. As least I hope he did.
Marcarl Posted February 7, 2013 #4 Posted February 7, 2013 I agree with Marcarl but would also question if you even need to change the plugs. You said that they were changed last year. How many miles since then? I should also point out, just in case there is any confusion, he made a typo...don't go out looking for a tin walled socket, he meant to type THIN walled socket. As least I hope he did. Well aren't they made out of tin? fuzzy!!!!
kkent66 Posted February 7, 2013 Author #5 Posted February 7, 2013 Thanks - I put roughly 15k miles last riding season. I did not catch the TIN socket - for some reason my mind saw it as thin!!!
KeithR Posted February 7, 2013 #6 Posted February 7, 2013 Get yourself a pc of 3/8" (if I remember correctly) hose so you can slip it over the end of the spark plug....makes it easier to start threading them back in. Keith
Freebird Posted February 7, 2013 #7 Posted February 7, 2013 Well, if it makes you feel better or is not running right, it certainly doesn't hurt to change them but I doubt they need it.
Yammer Dan Posted February 7, 2013 #9 Posted February 7, 2013 Well, if it makes you feel better or is not running right, it certainly doesn't hurt to change them but I doubt they need it. :sign yeah that: But I change mine a couple times a year just cause... Don't cost a lot and makes ya feel better. Autolites are a lot cheaper if you wanna save a few bucks. I had a tin socket once. I think...
dfitzbiz Posted February 7, 2013 #10 Posted February 7, 2013 I found that the sparkplug wrench that came with the standard tool kit works best for loosening and tightening and the air line hose works well for everything in between.
2WHEELSFORME Posted February 9, 2013 #11 Posted February 9, 2013 Plugs do not need to be changed often. If your bike is fouling plugs then you have another problem. I have an 05 with over 70K and have changed the plugs once about 25K ago.
dacheedah Posted February 9, 2013 #12 Posted February 9, 2013 I never did this with my 89 but must with my boat and truck, so I must ask does anyone index their plugs?? I know it's carbureted but could it effect the way it runs ??
kkent66 Posted February 10, 2013 Author #13 Posted February 10, 2013 Got my plugs changed without any issues. Found an 18mm thin wall spark plug wrench at Iron Pony - worked great. Also the tip about using a garden hose to get the plugs started worked well - thanks for all the help!
