Just looking for everyones take on the carb slide vacum hole location when reassembling carb slides on my 87. It looks like they should point down at 6:00.
I don't believe there is any orientation, it's simply a metering hole so rotational alignment is not important... but as you know, the diameter sure is!
Should be at the bottom to drain any possible moisture,,, at least that's the excuse we use around here,,,, might be different in other parts of the country, but we live here so go by the rules as we make them.
Hey.. I got one of the slides out of the carbs. One shattered :shock3:. Still have two left soaking with SeaFoam penetrating oil.
The carb that I was able to remove got one little chip on the outer edge this was on the side that faced the air cleaner. Would that have any impact on using it ? The chip is right on the beveled edge as shown in the photos below.
I hope the other two will come out soon.
Bill,
It doesn't look like it'd affect the slide. I'd inspect it real close for cracks, and if I could not see any I'd probably round the damaged area off a bit with some emery or sandpaper and then re-use it.
Frank D.
Ouch - has someone levered it up with a screwdriver ? You'd have to look at it in the carb to see if it would affect the vacuum, but those diaphragms look as if they've seen better days.
Good luck..
these were on one of my parts bikes. Looks like it sat outside without an air cleaner. They were stuck and I have been soaking them to get them out. The diaphragms are definitely toast. Just trying to get a couple out for one of the members here.
That's good - I'm glad to hear that you're not having to rely on them - doing a rebuild with dodgy parts and waiting to see if they do the job, or if your effort has been wasted, is a drag.
  • 2 weeks later...
