Ok, when I purchased my 2003 RSV about 6 weeks ago, the guy stated the previous owner was a female. True or not IDK. The bike came with a Corbin seat, that the guy claims he doesn't know if it fits, but came with the bike so OK. A few days ago I removed the seats and installed the Corbin. Here's the dilemma ( with pics to help): the rear portion of the seat seems too short. The little stem that should slide under the back seat post doesn't seem to reach. I was able to bolt down the front and it didn't seem to move at all. I just don't know enough about the bike or Corbin seats to see if it indeed is the proper seat. The sticker on the back says Corbin VENT-DT and the number next to the barcode reads 2303449. Can anyone help to determine if what I have indeed fits, or I have a $475 paperweight. It looks as if the end of the back seat is a bit further forward or "shorter" then original seat, but I would say not by very much. I am also showing some of the front, to see if thats the normal position. Any and all advice is appreciated.
*** I can not seem to add more then one pic*** grrrrrrr
Edited by Barrycuda
Proper description
Barry,
From what I have seen of the bikes I know of with Corbins on them it looks close, but the rear portion does seem a bit short to me. I know Freebird has a Corbin on his, you might want to PM him and pick his brain a bit....0.02
Looking at your picture and of the one on Corbin's website, it looks the same. The pics of the one on their site shows the same gap (to me).
The trunk may have been moved back which would cause that gap at the back.
That's what I was thinking as well. Gap look big to me.
I have a corbin on my mm venture and the gap at the rear of the seat is the same as yours, as for the rear mount, mine hooks fine front and rear.
You mentioned the part number was xxxx-DT. Maybe that is a Tour Deluxe version??? Are the rear seats the same on the RSV and TD??? Call Corbin and ask about the part number...
:detective:
Hey Barry
There is a Corbin showroom up in Ormond Beach just south of Destination Daytona. If you get over this to do that work you want to do, maybe we will have time for a test ride up tp Ormond, lt ls only about 30 miles. They can look at it for you.
What was making me curious was the fact the rear didn't lock in under the post, but everything else looked amid lined up OK.
Steve...I am still on board for our project and have to speak with you about dates and such. Stay tuned...
I will also look at the trunk positioning, and see if it needs to be moved forward. ( even I can do THAT....right) ????????
I've not seen a Corbin where there was a problem with the tab not being in the correct position. The gap on mine is about the same as yours if the trunk is bolted to the back set of holes. The tab lines up as it should though. The seat pans should be correct, it is the top/upholstered part of the seat that doesn't go back quiet as far. If your seat pan is actually to short for the tab to properly insert, you have a problem that I haven't seen before.
Thanks everyone for all your great help and advice. The weather here has been quite warm and nice with no rain,so it's riding time in between work. After the weekend, I will swap out and see what's going on. If everyone else's tabs line up, and Don says he has never seen that problem, then chances may be it was just me. I will keep everyone posted. Thanks again.
:fingers-crossed-emo
