First_N_Last Posted December 8, 2012 Posted December 8, 2012 Well the checks of my Trike have revealed its first problem. When I picked it up, I was told that a small dent was discovered in the front fender which was believed to be caused by the light-bar falling on the fender during a performed repair. After driving it home I discovered that the small dent is now a crease in what was my beautiful fender. Sooooooo... Anyone who has had their Venture converted with a Hannigan kit & EZSteer - Have you had problems with your light-bar hitting the front fender on hard bumps due to reduced clearance between the bar & the fender? I have a call into the previous owner... Before I attempt to fix the problem, I need to know if the reduced clearance is from the EZSteer install or some lowering adjustment performed. Any ideas or suggestions are welcome. Anyone know where I can get fender damage repaired like I have? Thanks as always - here are some photos. show two dents & ridge mark across fender shows small clearance problem
bongobobny Posted December 8, 2012 Posted December 8, 2012 Hmmmm, something ain't right there. Are the spacers under the light bar where the bolts mount?? Can't say that I've ever seen that issue, I have the EZ steer and no issues...
Bones158 Posted December 9, 2012 Posted December 9, 2012 I have the same problem but it is not from the easy steer. I have my forks lowered 3/4 of an inch in the trippletree. Its from the lowering bracket for the light bar made by a member Slowroll. (I see it in your pictures) The bracket lowers your light bar so you can remove the front fairing without removing the lightbar. I have two dents in mine even after replacing the fork oil with a heavier weight oil. Check your fork air pressure too, could be low. We might need to replace the springs with progressive springs.
Flyinfool Posted December 9, 2012 Posted December 9, 2012 If the paint is not damaged to bad, check with one of the Dent Wizard type places. I have seen them get out a lot of boo boos with out messing up the paint.
First_N_Last Posted December 9, 2012 Author Posted December 9, 2012 Thanks for all the info... The previous owner graciously contacted me & provided info. He had noticed that first fender dent about 3 years ago. The additional increasing denting appeared to be the result of hitting bumps on the way home (caused by the clearance issue). At least the mystery of the 3 year old dent is over. Now for the real problem of the clearance. The previous owner has not lowered the front end. The front end lowering had to have been done during the Hannigan conversion. Monday morning I'll be contacting Hannigan for their comments, etc. - Today I'm sending this thread & photos to Hannigan The light-bar extension was on prior to conversion & the light clearance reduction is a very minor contributor to this problem. Initially, I'll add air pressure to the front forks, then wait for Hannigan suggestions. Members, thanks for your help... JohnB
bongobobny Posted December 9, 2012 Posted December 9, 2012 Considering the front springs are around 10 years old maybe it is time for new progressives. Heavier springs also help out with front tire wobble according to a local RSV Trike owner. I've forgotten the name of another spring manufacturer that is better for the RSV but it is in a thread somewhere in the forums within the last couple of months. Just do a search using progressives and I'm sure it will come up...
bongobobny Posted December 9, 2012 Posted December 9, 2012 Per above, the springs are SONICS. Here's the link to the thread towards the end of the thread... http://www.venturerider.org/forum/showthread.php?t=68860&highlight=progressive&page=2
Carbon_One Posted December 9, 2012 Posted December 9, 2012 John my guess is that the springs need replacing with either a set of Progressives or Sonics. I had a set of Sonics in my 05 and loved the way the worked. Keep in mind that the Sonics are a straight spring not a progressive type. Anyhow While having them in I never had any issuse with bottoming out as in your case. Larry
Cougar Posted December 9, 2012 Posted December 9, 2012 (edited) Mine is a tad over 3 inches above the fender. in 4 years there never has been a issue. [ATTACH]73064[/ATTACH] Edited December 9, 2012 by Cougar
Bones158 Posted December 9, 2012 Posted December 9, 2012 Thanks everyone, looks like spring replacement for me to. I just measured 3 1/8" from the fender to the light bar. That is with Slowroll's bracket.
Cougar Posted December 9, 2012 Posted December 9, 2012 (edited) that is what my clearance is as well. no probems same set up, even with the light bar spacer. and my bike is 5 years older then yours Edited December 9, 2012 by Cougar
Bones158 Posted December 9, 2012 Posted December 9, 2012 Ok next question, how hard is it to replace the springs? Never tried this but have replaced the oil a few years back.
First_N_Last Posted December 9, 2012 Author Posted December 9, 2012 Mine is a tad over 3 inches above the fender. in 4 years there never has been a issue. [ATTACH]73064[/ATTACH] What I have to fix first is the clearance problem. My 2008 Royal Star Venture has 3 3/4" between the light-bar & the front fender. My problem 2002 Venture-Hannigan has just 1 3/4" between the bar & fender. Just 1 3/4" clearance is the main problem. If I have to disassemble the forks to fix, I probably should upgrade the fork springs also. Thanks; JohnB
Cougar Posted December 9, 2012 Posted December 9, 2012 Gotcha John.. looked like it was the same sorry.. YES there is a problem HUSTON ! Yeah that is way to close. please keep us informed as what has happened. I doubt Hannigan would have put the wrong rake kit on there and could cause that issue. but things happen I guess. Thanks, Jeff
Bones158 Posted December 9, 2012 Posted December 9, 2012 What I have to fix first is the clearance problem. My 2008 Royal Star Venture has 3 3/4" between the light-bar & the front fender. My problem 2002 Venture-Hannigan has just 1 3/4" between the bar & fender. Just 1 3/4" clearance is the main problem. If I have to disassemble the forks to fix, I probably should upgrade the fork springs also. Thanks; JohnB Wow, I don't think just the rake kit would shorten that distance, it only kicks the forks out more. Are the forks even at the top of the tripple tree?
Cougar Posted December 9, 2012 Posted December 9, 2012 (edited) it's a whole new piece that is replaced at the top go out and take a look it's a all new part notice the helmet locks are gone now as well Edited December 9, 2012 by Cougar
First_N_Last Posted December 9, 2012 Author Posted December 9, 2012 Is this Butch's Trike in the past Yes, this was Butch's Trike. With me riding it at high speeds across states & with a little more weight than him, the clearance became a BIG issue. So after doing quick research in the Tech Library, I found http://www.venturerider.org/forum/showthread.php?t=939 (Lowering the Front End - by Freebird). I think that by following this tech info & adjusting the forks down should solve the problem. Before I get started on this, has anyone done this without removing the lower part of the Front Fairing completely? I have no garage & will be doing this in the driveway. Damn I hate not having a garage! Of course I'll check all other measurements that I can to be sure that the problem is not something other than my planned fork adjustment. For the adjustment, I plan to adjust the forks to have 3 3/4" of clearance minimum. If that goes alright, I'll change out the fork oil to 15 weight while following this procedure http://www.venturerider.org/forum/showthread.php?t=57207 (Changing the Fork Oil). Please???? Anyone with TIPS, SUGGESTIONS, WARNINGS, ANYTHING to share, please do. I just want to get this done & fixed so I stop the damage, save money, save time & can finally ride again. I did not expect this type of repair was needed when I bought & all my planned money has been spent. Thanks in advance; JohnB
Bones158 Posted December 9, 2012 Posted December 9, 2012 John, find a tree near by. lol. My Venture will be picked up this week and triked by Hannigan through Trikes by Coach Rice in Loganville Ga. Kit will be ready on the 17th and trike delivered back the week after Christmas. Long time waiting. Hope all works out for you. Bob
ragtop69gs Posted December 10, 2012 Posted December 10, 2012 John, find a tree near by. lol. My Venture will be picked up this week and triked by Hannigan through Trikes by Coach Rice in Loganville Ga. Kit will be ready on the 17th and trike delivered back the week after Christmas. Long time waiting. Hope all works out for you. Bob Coach Rice did ours a few years ago and everything seems to have been done correctly. You're gonna love it.
bikenut Posted December 10, 2012 Posted December 10, 2012 On my bike I had the light bar bracket on to let me remove the fairing and with the bar bracket I also had the same thing yours looked like. A freind that is a body man fixed my fender and can not tell anymore. But Mine did it when I had to hit both brakes hard to try to stop when someone pulled out in front of me when I was going 60. Just missed the back side of the car but my Front fender had damage from the light bar being to low . Took off the bracket and no problems with 30,000 miles on the bike since. My bracket in on my work bench now Good luck
REDRIDER52 Posted December 10, 2012 Posted December 10, 2012 I did samething with mine sign along road said bump. It had a 2" hole clear across the road hit brakes as I hit the trench two big dings in fender
First_N_Last Posted December 11, 2012 Author Posted December 11, 2012 Had I known about this clearance issue, I WOULD NOT HAVE BOUGHT this bike. Why me? ARGH! Well, we learn & go on.
First_N_Last Posted December 12, 2012 Author Posted December 12, 2012 Today as I worked from home, I spent breaks & lunch working on the front end. I started by taking the fairing completely off... first the top half... disconnecting cables & more wire cables... finally, the bottom of the fairing is removed & the first sign of problems shows see the fork tube slid up about 2 1/2 inches in the photo? second sign - nut holding fairing bracket to the upper tree is missing. this nut is a nylon locking nut. they just don't loosen up & fall off. Forgot to tighten up? - probably here is the other nut on the other side of the bracket for reference... the fork tube in this picture is so loose that I can twist it with my hands... More work tomorrow & more photos... I tried taking some short cuts, but with all the work I know I have to do now... pausing to - remove gas tank - remove front fender - remove front wheel - remove front brakes - Damn!
First_N_Last Posted December 12, 2012 Author Posted December 12, 2012 Well at this point I have the anxiety of having to wait until tomorrow to dig in deeper to this issue. What I am certain of at this point: this front end clearance looseness had to be noticed in some way or form by the previous owner the nylon self locking nut could not have been tightened properly if it just fell off the left fork being that loose & slid up means the right fork spring has to have suffered compression damage because it was the only spring providing suspension action. because the right spring is damaged, I'll have to at least replace both fork springs now my experience has been that forks don't come loose unless they weren't tightened to spec when assembled I AM NOT HAPPY! I hope I just find loose clamp bolts & not stripped bolts tomorrow. Stay tuned for more frustration to be endured by me & to bring smiles to others who may have suffered similarly. JohnB
