My class has an e-1 error. When the key is turned to acc there is no sound from the system. I used another none good panel with the same results. Any ideas where to start or any known issues that cause this code? :confused24:
The troubleshooting manual points you immediately at the discharge valve if no noise is heard when the ignition is moved to ACC. I believe you should hear a momentary release of air.
