Cougar Posted December 8, 2012 #26 Posted December 8, 2012 Leo, I have also pulled the clutch cover off my trike and I don't even think I lost more then a teaspoon worth of oil.
bongobobny Posted December 8, 2012 #27 Posted December 8, 2012 Do the clutch when you change the oil...
leo3wheel Posted December 10, 2012 #28 Posted December 10, 2012 Leo, I have also pulled the clutch cover off my trike and I don't even think I lost more then a teaspoon worth of oil. Hi Jeff, Not really worried about losing oil. Can coordinate work with oil change. Will visit clutch issue in spring. Too old to work in the cold. Know relacement clutch is stronger, but wonder if it is necessary for our western trip next summer. Hate to replace parts unnecessarily. Will have to experiment with pulling our trailer in the spring to see how trike performs. Thanks!
Cougar Posted December 10, 2012 #29 Posted December 10, 2012 Leo, a couple years ago I just did the spring upgrade ONLY and I pull a trailer as well no problems so far so good
Carbon_One Posted December 10, 2012 #30 Posted December 10, 2012 Leo, a couple years ago I just did the spring upgrade ONLY and I pull a trailer as well no problems so far so good On my 05 trike the clucth stated slipping after about 10,000 miles so I put in the PCW clutch upgrade. No New discs as they were still within specs. 35,000 miles later all was still good. The 09 I now have has just under 10k on it but I'm going to do SkyDoc's upgrade before the winter is over. Already have the parts so once I get a chance it'll be done and one less thing I'll have to concern myself with later on in the riding season. I tow a trailer quite often and with the bikes extra weight I just feel better doin it now rather than later. Larry
bongobobny Posted December 10, 2012 #31 Posted December 10, 2012 My clutch started slipping after about 5K as a trike, but I also did a lot of slipping getting used to the extra weight of the trike. Basically what happend is when it starts to go it slips when you get on it too hard. I drove for several thousand miles that way bwefore I finally got around to changing it. Actually, I sweet talked Squidley to do it at MD...
leo3wheel Posted December 10, 2012 #32 Posted December 10, 2012 Sounds like I should start by ordering the parts. Then, I'll take it from there. I would feel better going west with the stronger clutch.
hillrider Posted December 11, 2012 #33 Posted December 11, 2012 Way back in the third post of this thread. What's a "cam type Allen Wrench"? Is that another way of saying "Ball Head"?
First_N_Last Posted December 11, 2012 Author #34 Posted December 11, 2012 Way back in the third post of this thread. What's a "cam type Allen Wrench"? Is that another way of saying "Ball Head"? yep
First_N_Last Posted December 11, 2012 Author #35 Posted December 11, 2012 more parts arrived yesterday... Signal Dynamics StarBurst headlight modulator Barnett Heavy Duty Pressure Plate springs "Green"(82lbs vs 75) front air deflector side cover bolt "GhostR" custom license plate Almost enough to really get started & get it done...
First_N_Last Posted December 18, 2012 Author #36 Posted December 18, 2012 more parts arrived yesterday... Signal Dynamics StarBurst headlight modulator Barnett Heavy Duty Pressure Plate springs "Green"(82lbs vs 75) front air deflector side cover bolt "GhostR" custom license plate Almost enough to really get started & get it done... More parts came... another clutch cover gasket the correct extra clutch friction plate I now have all the parts to finish the clutch upgrade, but I'm ordering the front fork parts today. The forks have to be finished & assembled before I continue now. I want to - have to do them right. progressive springs 15 weight fork oil - 2 liters fork-cap O-rings torque all mount bolts & 2 locking nuts Photos to come... JohnnyB
First_N_Last Posted December 21, 2012 Author #37 Posted December 21, 2012 Almost ready to start working on it again... Yesterday I bought a new in.lb. Torque Wrench & ft.lb. Torque Wrench. Members gave me recommendations for Fork Bolt tightening also. Today my Progressive Springs and two liters of 15 weight Fork Oil arrived. Amazon is FAST! All I'm waiting for now are the cap O-ring seals for the fork tubes, & some not-so-cold days. JohnnyB
ragtop69gs Posted December 21, 2012 #38 Posted December 21, 2012 The last item may be the hardest to come by.
First_N_Last Posted December 21, 2012 Author #39 Posted December 21, 2012 The last item may be the hardest to come by. if I have to wait too long, I just might buy a tent (or make one) & put a heater in it to make a sort-of-garage.
ragtop69gs Posted December 21, 2012 #40 Posted December 21, 2012 Or you could throw it on a trailer and bring it over here, I'll fire up the furnace in the garage
First_N_Last Posted December 21, 2012 Author #41 Posted December 21, 2012 Or you could throw it on a trailer and bring it over here, I'll fire up the furnace in the garage Darn Jay... 1st - I feel bad that I don't have a garage Now I feel bad that I don't have a trailer Darn - what next? JohnnyB
Carbon_One Posted December 22, 2012 #42 Posted December 22, 2012 Darn Jay... 1st - I feel bad that I don't have a garage Now I feel bad that I don't have a trailer Darn - what next? JohnnyB The fact that you're to far away for us to be of much help to ya. Larry
First_N_Last Posted December 22, 2012 Author #43 Posted December 22, 2012 Just ordered Speed Bleeders for brakes & clutch.
First_N_Last Posted December 31, 2012 Author #44 Posted December 31, 2012 Getting tired of waiting for warm days so when it is above 40 with winds below 10 mph I've been outside doing it... I loosened the other fork cap & pulled both forks off. Here is a pic showing the standard fork spring next to the progressive/washer/spacer then I drained the fork oil - flushed with ATF - drained again - flushed with ATF again & drained... changed the fork cap o-ring I added the new fork oil in at 250ml increments (x2 for 500ml total) The 500ml amount was determined by filling the collapsed/compressed fork tube without spring & spacer installed. Progressive Spring instructions recommend oil filled to 5 1/2" below top of tube after the oil was added & level checked - added the spacer & washer (spacers were made/cut to 6 3/4") then I added the spring as I extended the fork... (springs are 15 1/2" long) the sun went down... so I screwed on the fork caps & stopped until the next day. Next day - put the forks on - torqued - double checked torque Put front wheel on - put brakes on... I finished today's efforts by putting on handle bars - realizing I forgot to put the cap on steering neck nut - took the bars back off - put the cap & bolt on - put bars back on. All fork clamp bolts were torque check again. Then again... then again. Last thing for today, I put the lower part of the fairing back on after threading all the cables. Next discovery is some strange wiring - that's tomorrow's episode. If it is not raining lots of stuff should get done. JohnnyB
bongobobny Posted December 31, 2012 #45 Posted December 31, 2012 Great so far Johnny!! I'll be doing the same thing in March/April...
First_N_Last Posted December 31, 2012 Author #46 Posted December 31, 2012 By the way - The tire pictured is my tire off my old bike. Yep - I took the Avon Venom Reversed Rear Tire I had on the front (cracks & all) swapped it with the newer E3 & put the E3 on the old bike as part of checks. It was easier to leave it that way & better for selling the bike (prettier than cracking Venom). The Avon with 10,000+ miles had more tread than the newer E3 front. Just have to live with the cosmetic sidewall cracking. JohnnyB
ragtop69gs Posted December 31, 2012 #47 Posted December 31, 2012 Did you remember to check the neck bearing torque while it's apart ?
First_N_Last Posted December 31, 2012 Author #48 Posted December 31, 2012 Did you remember to check the neck bearing torque while it's apart ? Sure did - 44 ft.lbs.
First_N_Last Posted December 31, 2012 Author #49 Posted December 31, 2012 (edited) I just couldn't get myself out in the cold to do any work, but I did take some photos... to generate awe & wonder... Now look at this BLUE wire - what was the purpose behind the Crimp-Splicers? Were they really just making a long blue wire out of three small pieces of blue wire? ...or was the there a purpose beyond what a normal mind can understand???? The same for this yellow wire - just making a longer yellow wire? ... or was this a secret way of making this bike run better, faster & more efficient? Is this technology & knowledge lost in the last few years? or just piss poor wiring???? Everything I look at seems to need attention. I will prevail - I have the knowledge & technology - solder - soldering iron - electrical tape - decent quality crimp connectors - heat shrink - heat gun - common sense It's just that my patience is running thin - WHAT NEXT - Ha! What wonders of wiring, technology, etc. will be revealed when I take the gas tank off? Huuuummmmmm I'll wait a year before I do that. JohnnyB Edited December 31, 2012 by First_N_Last
Carbon_One Posted January 1, 2013 #50 Posted January 1, 2013 I hate to see those wire connectors used for anything that is exposed to the elements. Moisture, then corrision,then failure is generally the results of using them. Jay (ragtop69gs) had a ball trying to locate a power failure and eventually found the voltage loss at one of those connectors on his bike. John you're doing yourself a favor doing the repairs the old and best way, solder and shrink tubing the connecting wires. Larry
