Jimod Posted December 1, 2012 #1 Posted December 1, 2012 My radio is stuck on AM. Won't change to FM. Has anybody else had this problem and how did you fix it ? Jim O'D....... Australia
MiCarl Posted December 1, 2012 #2 Posted December 1, 2012 Mine was full of problems with those switches. Turned out they needed cleaning. If you disassemble the control unit you will find those buttons are backed by a molded rubber sheet. Under the sheet is a circuit board with switches mounted to it. I sprayed electronics cleaner into each switch and operated it several times while still wet. That cleared up the problems. Someone also had a line on replacement switches. Perhaps something will turn up as the rest of the U.S. gets out of bed.....
OrlinEngh Posted December 1, 2012 #3 Posted December 1, 2012 Had the same problem gave it a good cleaning and all fixed, gave the tape deck a good cleaning and its working to. Orlin
Jimod Posted December 1, 2012 Author #4 Posted December 1, 2012 Thanks Mike I pulled the unit out and flushed the switch with electrical contact cleaner and now it works as new ! Jim
