djh3 Posted November 29, 2012 #1 Posted November 29, 2012 I was messing around the other day and using my cell phone for Pandora. After awhile I switched to regular FM radio. I had to really turn down the volume as it about blew my ears out. I flipped on the CD to listen to something after that and had to turn down a little more, not as much as before. Of all the music I would have to say the CD player has the clearest and loudest out put. The Aux the least. Why? Maybe because you have to run it thru so many cables etc to get anything? Just wondering, and has anyone else experienced the same?
eusa1 Posted November 29, 2012 #2 Posted November 29, 2012 turn the volume setting up to max on your phone, and you will find it to be better than all the rest by far.
jneed53 Posted November 29, 2012 #3 Posted November 29, 2012 I agree with eusa1. I use an ipod turned to max and keep my system volume around 19-20 and it works fine.
Caveman Posted November 29, 2012 #4 Posted November 29, 2012 I turn my ipod to max and aux vol of 16 is about all I can stand.
djh3 Posted November 29, 2012 Author #5 Posted November 29, 2012 Yea I noticed I had to turn the phone way up. 2 things happen when I do that. A warning about possible hearing damage (I supose thats true if you had ear buds in). Also it sounds as though it distorts. So I cant really turn it up to say 10 I can only run around 7 say. I dont know what the exact setting is, but you get my drift. I also tried running my boosteroo on the phone but the battery croaked about 10-15 min in so not much comparison time. Also it will run the battery in the phone down quicker, but I have a charger hooked up if playing music from phone. I learned the hard way it dont last very long.
Rick Haywood Posted November 29, 2012 #6 Posted November 29, 2012 I shut my stereo off and just listen to EUSA1's when I ride with him
dacheedah Posted November 29, 2012 #7 Posted November 29, 2012 Ouch, I like the pandora, I can run gps drive in the background and hear it all, sounds good nuff 2 me
alwrmcusn Posted November 29, 2012 #8 Posted November 29, 2012 JFI: When you record your own MP3's you may find that there is a wide range of "volume" between some of the songs (taken from different CD's/sources). I use a freebie software called "MP3Gain" to equalize the volume and set an output level across the entire MP3 section on my SD card (GPS use) or my MP3 player.
