cheny Posted November 28, 2012 #1 Posted November 28, 2012 Hi all Is there a easy way to put a meeter on the cb cable to match the antenna? cheny
dynodon Posted November 28, 2012 #2 Posted November 28, 2012 you have to follow the wire to the connector that will mate up with your meter. I think I did that one time, but I can't remember exactly where it was. Under t he seat.
Rick Butler Posted November 28, 2012 #3 Posted November 28, 2012 Cheny, The CB is located under the trunk. And you will need a couple of Motorola adapters since most SWR meters use the bayonet style and our bike uses the Motorola type. Rick Hi all Is there a easy way to put a meeter on the cb cable to match the antenna? cheny
etcswjoe Posted November 28, 2012 #4 Posted November 28, 2012 Cheny, The CB is located under the trunk. And you will need a couple of Motorola adapters since most SWR meters use the bayonet style and our bike uses the Motorola type. Rick Make sure the adapters mate good the ones at Radio Shack do not work that well. I like Walcott CB online. http://www.walcottcb.com/cb-coax-cable-coax-connectors-and-adapters-c-377_355_443.html
