ssimar4 Posted November 26, 2012 #1 Posted November 26, 2012 I bought this 2006 Midnight RSV and the previous owner said he never used the CB, I have read all the threads on CB issues, the problem is the CB will come on and I get a CBERR message and it shuts off after about 15 seconds, I've checked all the connections as described on the forum and I do get 12 volts at the connector at the CB unit uder the trunk. Any Ideas?
etcswjoe Posted November 26, 2012 #2 Posted November 26, 2012 Just to double check did you look at the connectors inside the waterproof enclosure and the ones behind the fairing?
Wayne McClain Posted November 26, 2012 #3 Posted November 26, 2012 ....yes ,the ones behind the fairing do check those and you may want to go ahead and grease them up with dielectric grease...this caused all my cb woes!!
ssimar4 Posted November 26, 2012 Author #4 Posted November 26, 2012 Yes, I did check the ones behind the front fairing especially the yellow one, I also Ohmed the wires from the front to the rear and checked OK, the one under the passenger seat seemed a little loose so I taped it to make sure, Thanks, Steve.
Kirby Posted November 26, 2012 #5 Posted November 26, 2012 Also, check to make sure your CB is actually connected to the CB antenna. A lot of these bikes come from the dealer with the antennas on the wrong side. The CB should be on the left (sitting on the bike)and connected to the Cb " blackbox" which is located under the trunk. Just to make sure, trace the cable from the antenna to the CB.
ssimar4 Posted November 28, 2012 Author #6 Posted November 28, 2012 Yes, I checked the antennae and was hooked up and I checked continuity of the wire and it appears to be good.
playboy Posted November 28, 2012 #7 Posted November 28, 2012 When I had that problem I cleaned the plugs under the fairing and all was well. I say cleaned all I did was unplug them spray with wd 40 because it was all we had at the motel and plug them back up again. I would go back in there and re check them and pay attention to the male ends to make sure no pins were broken off and stuck in the female ends. If they had never been apart I could see one of them breaking off when unplugged and remaining in the female end and easily going unnoticed.
Seaking Posted November 28, 2012 #8 Posted November 28, 2012 Just a shot in the dark if all else fails.. I had those same problems and tried all the same great fixes folks have been offering, which did help some.. But what fixed my CB issues was relocating the wire bundle that comes around the steering neck and back up to the radio controller.. the wires were squished against other wires, and by moving the wires on top of the other so they were no longer binding or being squished resolved all my problems.. dunno if that would work in your case.. but that's what fixed my problems.. Best of luck..
ssimar4 Posted November 28, 2012 Author #9 Posted November 28, 2012 Thanks for all the tips I'll try again tomorrow and let ya'll know, one thing I did try was put my helmet on and tried it through the helmet headset, I could hear the radio fine but tried the CB and could not hear nothing even if I pushed the press to talk switch before it shut itself off.
playboy Posted November 28, 2012 #10 Posted November 28, 2012 Does it only shut off when the cb is on ?
BradT Posted November 28, 2012 #11 Posted November 28, 2012 playboy said: Does it only shut off when the cb is on ? Good question as the problem needs to be narrowed down a little. Checked the braided ground wires from the unit under the fairing. Not sure what the unit is but it is Clarion and these had some issues in earlier years. Good luck Brad
wes0778 Posted November 28, 2012 #12 Posted November 28, 2012 When I got that error, I finally traced it to the connector under the passenger seat. It was like the wires should have been at least a silly millimeter longer, because I could almost not get the plug completely seated.
ssimar4 Posted November 28, 2012 Author #13 Posted November 28, 2012 Playboy, yes just the CB shuts itself off after after about 15 seconds.
etcswjoe Posted November 28, 2012 #14 Posted November 28, 2012 Are you truning it on with the CB button on the controller or does it come on when you turn the bike on?
ssimar4 Posted November 28, 2012 Author #15 Posted November 28, 2012 Yes, I'm turning it on with the CB button and it still goes off after 15 seconds, I did check all the connections again in the front and back, no bent pins and everything looks OK, also checked the ground. I also re-positoned all the cables with the same results, could it be the unit under the trunk is bad?
ssimar4 Posted November 28, 2012 Author #16 Posted November 28, 2012 Yes it shuts of with the helmet cord plugged or not plugged in, and being a 2006 I'm pretty sure the waranty ran out, I also tried the tape player it don't work either, not that I would ever use it. Thanks for all the suggestions.
