PGunn Posted November 9, 2012 #1 Posted November 9, 2012 I just found this PDF on how to mod the flasher relay on the Gen2 to work with LEDs and not have fast flashing and have the cancel and 4 way working. I found the doc here http://www.650ccnd.com/PDFs/Flasher_mod_Revised.pdf
djh3 Posted November 10, 2012 #2 Posted November 10, 2012 Does it say weather or not the auto cancel also still is operable?
MikeWa Posted November 10, 2012 #3 Posted November 10, 2012 Great post. I think I will put in a small rheostat so I can adjust the blink rate. Mike
ChrisFrench Posted November 10, 2012 #4 Posted November 10, 2012 Hello, It is easier to put an electronic flasher http://cgi.ebay.fr/3Pin-CF13-Centrale-Clignotant-LED-Relai-Flasheur-Flasher-Electronique-Top-/221137121100?pt=FR_JG_Auto_Tuning&hash=item337cccaf4c Chris
djh3 Posted November 10, 2012 #5 Posted November 10, 2012 The RSV flasher unit also integrates the auto cancel feature. So it turns the flasher off after you make the corner or a few minutes. I tried just removing the pins for the flasher and slaving in a LED flash unit and couldnt get the shut off feature to work. But if you dont care abuth the shut off feature sure.
PGunn Posted November 10, 2012 Author #6 Posted November 10, 2012 djh3 said: Does it say weather or not the auto cancel also still is operable? First line in the pdf: "I was looking at getting LED turn signals, but I didn't want to have fast flashing signals, (it reminds me of the old thermal mechanical ones when they were ready to die) or loose the self-canceling feature." I would think so he does not say it stopped working. Also I would get one off EBay just to try it on, they are if I remember right are around 7.00 each and if you screw it up you still have the one working on the bike.
