Atoolnut Posted October 22, 2012 #1 Posted October 22, 2012 Well I have searched the threads re this and went out and got a complete setup (in fact 2 set ups) 1 from an 07 roadstar with 14mm master and calipers and all lines inc splitter...#2 is a R6 blue dot caliper complete with master also 14 mm bought the R6 first and will be selling them after install......I am going to use the roadstar m/c and roadstar calipers as they look the same as R6...they have chrome dots .....Are these calipers the same internally? both are 4 piston.....the lines from RSV and roadie are same length banjo looks a little different...I will be replacing stock lines with SS....and EBC pads.....why the use of a Vmax splitter?is it for better flow?.also will roadie floating rotors fit..they are same dia. and have saame # mounting holes any problems that i might run into thanks for any info Les
bongobobny Posted October 22, 2012 #2 Posted October 22, 2012 OK the R6 blue dot is pretty much the same as the RSV/RSTD. They have steel pistons. The sought after R6 gold dots have aluminum pistons that won't rust and/or hang up from the rust...
Atoolnut Posted October 22, 2012 Author #3 Posted October 22, 2012 thanks are the roadstar pistons steel or aluminum?are they the same as stell R1/R6? this hang up is it common after bike sitting or does the piston put a ridge in bore?
skydoc_17 Posted October 23, 2012 #4 Posted October 23, 2012 Hey Les, The Roadstar front calipers have the steel pistons. If you flush/bleed the front brake system yearly, this will minimize the rust problem. Brake fluid should be the color of water, if it is any other color, then it is time for a flush/bleed job. I have a set of aluminum pistons from an R1 if you are interested. Have a look at this link, it shows the S.S. line set I offer with the modified VMAX splitter and S.S. mounting bracket. http://www.venturerider.org/classifieds/showproduct.php?product=4052&title=second-gens-sbrake-2fclutch-5-line-set-21&cat=22 I have it in stock in black, but can order it in Silver, red, blue and green. I keep a full line of EBC HH pads for your bike in stock. If you have any other questions, or need parts, please feel free to PM me. Earl
djh3 Posted October 23, 2012 #5 Posted October 23, 2012 I did a little reading here and there. On another venture site a fellow had a write up about "linking" the front and rear brakes. Does this kit do this? Is this something maybe to look into? Is there a brake "upgrade" for the rear. I have read something about an R1 mod. Is that just so you get the alum pistons for the calipers? What does it do for you?
Atoolnut Posted October 23, 2012 Author #6 Posted October 23, 2012 Sydoc thanks for info..re R1 pistons ..how big of a job to swap out and what is cost?..could you explain why the vmax splitter is better..I would think that 2 lines off central is more effective than one line ahead of the other
Atoolnut Posted October 24, 2012 Author #7 Posted October 24, 2012 Today I tackled this project..strightforward after following all previous posts and helpfull advice.....swapped out for 07 roadstar calipers with 14mm master from same bike.(ebay find)also changed lower lines to roadstar as they seemed to fit better....Went for a small ride around the block..WHAT a difference...much more control.easier pull on lever..faster and shorter stopping distance..Yamaha should do this upgrade....I cant see if SS lines and vmax splitter can make more difference , same for R6 rotors ..this upgrade seems a good step, will see when riding 2 up and loaded Now have full set of 08 RSV calipers and M/C for sale Also R6..calipers no pads for sale $40 plus shipping
karlfitt Posted November 2, 2012 #9 Posted November 2, 2012 Did I read this right, you also used R-6 rotors? What year? TIA
Atoolnut Posted November 3, 2012 Author #10 Posted November 3, 2012 didnt use r6 rotors yet but looks like up to 04 will fit........07 roadstar also fits...have r6 calipers for sale....pm if interested
