AlbertaClipper Posted January 27, 2008 #1 Posted January 27, 2008 Has anyone installed their Garmin GXM-30 under their front fairing? Results?
BEER30 Posted January 30, 2008 #2 Posted January 30, 2008 I have the GXM-30 antenna mounted via velcro onto a platform I made onto my mirror mast . Normally my radar detector is mounted there , so I occasionally toss the GXM-30 into my windshield bags and have notice less quality reception . I've wondered myself about placing under the fairing , but I use the ZUMO in my cage as well , so I will not mount under the fairing . BEER30
TxGent Posted February 11, 2008 #3 Posted February 11, 2008 I've had the GS-30 Antenna mounted under my fairing for going on over a year. The reception is fine, however when I was in the mountains in NC, I would occassionally loose signal, but not sure if that was because of the location of the antenna, or just the geography I was in. I used the 3M double sided tape, and positioned it as high as it would go inside the fairing, and still allow me to bolt the fairing cover back on. Hope this helps
Midrsv Posted February 11, 2008 #4 Posted February 11, 2008 I've had the GS-30 Antenna mounted under my fairing for going on over a year. The reception is fine, however when I was in the mountains in NC, I would occassionally loose signal, but not sure if that was because of the location of the antenna, or just the geography I was in. I used the 3M double sided tape, and positioned it as high as it would go inside the fairing, and still allow me to bolt the fairing cover back on. Hope this helps That really surprises me. I thought XM had to have a view to the sky above. That's why it drops out in my garage and going through tunnels. DT
Freebird Posted February 11, 2008 #5 Posted February 11, 2008 It kind of surprises me also. Although, I also have a home cradle for one of my XM units and found that with the home antenna sitting on top of my entertainment center it would work if I had it aimed exactly right. In regards to riding in the mountains, I sometimes lose the signal also and my antenna on the bike in mounted on top of the clutch reservoir. Also happens sometimes where there is heavy tree coverage beside the road.
