besttec Posted October 6, 2012 #26 Posted October 6, 2012 Yesterday one of my co-workers was packing to leave earlier than usual.. and I asked what was up. She said one of her monitors went out... quit working. I said "did you bump the power switch?" (which is very prominently positioned on the lower corner of the flat panel monitors). She promptly said "No"... then sheepishly "yes"... Ya gots to pay that atenshun! ;-) Actually, my problem with the RSMV audio system is setting the radio stations and presets... the manual doesn't seem clear at all... and when I figure it out it only takes a week of not using the procedure to wipe it from my brain. I figured it out again after the power was interrupted... and it has been about a week... so I am not sure if I still remembrer the procedure or not!!! ;-) Your problem was fixed with what I was going to suggest! Congrats!
CaptainJoe Posted October 6, 2012 #27 Posted October 6, 2012 Glad you got her fixed. If I remember correctly, another thing that will cause it not to work is putting your ipod in the cassette door(just to hold it). Ihought i had found a use for the cassette player but the aux won't work if the cassette senses something in it. Think it might have something to do with the door not closing? been a couple of years ago...Will test and let you know.
