bikerjohn Posted September 15, 2012 #1 Posted September 15, 2012 just got a old motorcycle off of craiglist pretty ruff shape. No si covers so ihv no idea wa kind of bike it is. It is a Kawasaki big 4 cylinder (not V) possibly 99 or 2000 Shaft drive Disc brakes in front and Drums in back. I have the vin but not sure if I can tell from the vin. Anyone have any clues?
Freebird Posted September 15, 2012 #2 Posted September 15, 2012 If you post a picture, I bet we'll figure it out. They made a lot of bikes that fit that description. Could be a KZ900, KZ1000, there were others also. I think they also made a 750.
Prairiehammer Posted September 15, 2012 #3 Posted September 15, 2012 Go here and enter your VIN in the provided box for a description and model of the bike: http://www.motoverse.com/tools/vin/kawasaki.asp
bikerjohn Posted September 16, 2012 Author #4 Posted September 16, 2012 here are a few pictures I could not fnd te VIN what i have is the number on the egine casing. Also it has overhead cam and plugs go in to the top
Guest scarylarry Posted September 16, 2012 #5 Posted September 16, 2012 I'm guessing no title either..
bikerjohn Posted September 16, 2012 Author #6 Posted September 16, 2012 No i picked it up to scrap it. But there are usable parts. so if I can figure out what it is then I could help someone with parts.
MiCarl Posted September 16, 2012 #7 Posted September 16, 2012 Kawasaki inline 4, shaft drive. Not ringing any bells here. The VIN should be stamped on the head stock. If it's got 17 digits the motoverse tool posted by Prariehammer should ID it. If it's got less than 17 you have some sleuthing to do.
Wrench Posted September 16, 2012 #9 Posted September 16, 2012 I found a pic of a '98 650 Eliminator. Going by what's left of yours this is my guess,,,
pmelah Posted September 16, 2012 #10 Posted September 16, 2012 thats the first bike i ever owned nd learned on as far as motorcycles go it was a nice bike
JohnT Posted September 16, 2012 #11 Posted September 16, 2012 They also made a ZL1000 that was shaft. And Kawi also made several other shaft drive KZ models. Search the VIN on line.
bikerjohn Posted September 16, 2012 Author #12 Posted September 16, 2012 Thanks i think i found it. 1997 ZL 600 Eliminator inline 4 / shaft Drive / liquid cooled/ 6 speed and it looks to be the same Thanks for the help.
Gray Ghost Posted September 17, 2012 #13 Posted September 17, 2012 To determine the year from a 17 digit VIN, the tenth character denotes the year. System started in 1980, with "A" denoting the year, alpha characters were used through 2000 (Y), skipping the characters I, O, Q, U, Z. In 2001 through 2009, numbers were used, except 0. So 2001 would have 1, 2009, 9. In 2010 the system starts back with alpha characters. Harley also puts model, engine size, and assembly plant in the VIN as well. Kawasaki probably does, but I don't have a cheat sheet on them. BTW, 1997 is "V"
djh3 Posted September 18, 2012 #14 Posted September 18, 2012 Normally on the jug somewhere there is the CC size. Typicaly a 650 would be in the 645-650 range and a 1000 like 980 and up. I think my KZ 650 was like 649. And WOW a Dunlop D404 that still has air and tread.
