Trying to find a replacement air line that goes from the little hole behind the Front seat to the rear shock. Mine is missing and I have no way to check or add air to the rear shock. (without taking the rear tire off- my hands are too big to get in there). Looking on e-bay and parts places but no luck yet. Anyone have a idea where to look for one?- Thanx in advance oh for a second gen btw.
Guest scarylarry
Strange I found the shock but no size or part # for just the line...
If the valve stem is still there pop off the black plastic ring and remove the whole valve stem and take it to a auto parts store to get the right size line. Shouldn't need over 12'' and trim to fit.
http://http://www.venturerider.org/forum/attachment.php?attachmentid=71619&stc=1&d=1347747359 Never mind I see that it is crimped on so what I had in mind won't work. Maybe someone who has a bad shock laying around could help.
Guest scarylarry
Maybe a gasket and rubber place can make one...We have on in Nashville I know that won't help you but maybe there is one near you or dealer should have it...
Does it look like this would work?
This line is from the rear shock on a 1st gen without a air compressor.
Overall length is 9"
Gary
http://i1007.photobucket.com/albums/af193/gdingy101/rearshockairline.jpg
Hmm thanks for the ideas, not sure if that will work or not-- I dont know what original looks like-- I just have a valve stem sticking out of shock and everything else is gone. But if I cant find one I know I can make one. So thats the route Ill start working on. Thanks again, just wanted to be sure I wasnt over looking, where I might be able to buy a replacement.
The one Dingy posted looks like it would work compared to the pic of the original that I posted. Anyone that's has a bad 2nd gen shock laying around might remove there's and send you.
Dingy, from looking at the pictures ive found - it does look really close, Ill wait till this winter or until I get more time and will pull rear tire off. untill then I wont know for sure till I can get in there and pull the old valve stem off and see the size and stuff. Its possible it might just work. Ill also check for lengh then too- see if it would reach or reach to another spot where I could mount it. I could still adapt it and lenghen it needed- let me know what ya want for that and Ill send ya some money plus shipping costs.
Im the one that was looking for the airline-the one Dingy pictured there was from a first gen. But I was thinking I could make it work. if you have one from a second gen and want to part with it- id happily pay ya for it.
The picture I posted was of a line I need, Sorry !!
I am putting together Tweety II starting this winter and it will be a bare bones look, no air compressor.
I looked through my sizable parts stash last night and could not find another for you. I also think one from the front forks of a 1st gen would work. One without a compressor. These had the Shrader fitting mounted on a bracket near the key switch. Probably about 8" long. I have one of them but need it also. Picture attached of front one from a compressor equiped bike, but other is similar..
Gary
Hazen,
I have a 2nd gen parts bike, take a pic of exactly what you need and I can get the one from the parts bike. Better yet just call me, my cell # is in my profile.
