GolfVenture Posted September 13, 2012 #1 Posted September 13, 2012 Anyone know where one can order replacement lenses. Small one is for the lower wrap around side bag guard. Larger one is for the lower chrome unit below the turn signal and Yamaha Lens.
pmelah Posted September 13, 2012 #2 Posted September 13, 2012 Good question ive got quite a few that look like the one on the left in your pic and need to replace them im thinking about getting the kit that lets you make them youself seen it on american restoration once
van avery Posted September 13, 2012 #4 Posted September 13, 2012 I have been told you can put them in Red dye ( LIKE DYING CLOTHES) and it will turn them back to red. I also heard that you can paint them with candy red model airplane paint.
Guest scarylarry Posted September 13, 2012 #5 Posted September 13, 2012 Do you have a truckers supply where you are at? Might check with them if you do..
cabreco Posted September 13, 2012 #6 Posted September 13, 2012 Golf&Venture said: Anyone know where one can order replacement lenses. Small one is for the lower wrap around side bag guard. Larger one is for the lower chrome unit below the turn signal and Yamaha Lens. I replaced mine too. Got them from Cycle Parts Nation. These guys shipped fast & they fit perfect. http://www.aftermarketcyclepartsnation.com/Drag-Specialties-BARON-TWIN-AND-BARON-MINI-TWIN-MARKER-LIGHTS-detail.htm?productid=7922788
GolfVenture Posted September 13, 2012 Author #7 Posted September 13, 2012 I will look into the red clothing dye for I have 12 small lens and 10 large lens.
djh3 Posted September 13, 2012 #8 Posted September 13, 2012 Snoop around some of the antique car fourms and see what tricks those guys have up thier sleeves. Surely this cant be the first time someone has needed to do this on obsolete lenses.
Pegasus1300 Posted September 13, 2012 #9 Posted September 13, 2012 as brake pad said they are available from JC Whitney. They have both sizes. They also used to be available from Drag Specialties maybe still are.If you just want to recolor them Eastwoods used to have a paint/dye to recolor old lenses.
mbrood Posted September 13, 2012 #10 Posted September 13, 2012 You can get new ones from Drag Specialties http://asset.lemansnet.com/static/sites/dragspecialties/flipper/2012Fatbook/#page=793 Running Light replacement lenses Drag Specialties DS-28015 large red DS-280153 large amber DS-280168 small red DS-280167 small amber Commonly known as Baron's and Mini-Baron's
GolfVenture Posted September 15, 2012 Author #11 Posted September 15, 2012 I bought a spray can of red lens spray at an auto store, and sprayed the inside of the lens. Does one also spray the outside surface of the lens or just give the insde another coat? Being that I have 22 to replace, I think the spray can is the way to go.
GolfVenture Posted September 18, 2012 Author #12 Posted September 18, 2012 Brake Pad said: JC WHITNEY Catalog Can't seem to find them on the search.
GolfVenture Posted September 18, 2012 Author #13 Posted September 18, 2012 cabreco said: I replaced mine too. Got them from Cycle Parts Nation. These guys shipped fast & they fit perfect. http://www.aftermarketcyclepartsnation.com/Drag-Specialties-BARON-TWIN-AND-BARON-MINI-TWIN-MARKER-LIGHTS-detail.htm?productid=7922788 I can't seem to find them. Any search hints?
GolfVenture Posted September 18, 2012 Author #14 Posted September 18, 2012 mbrood said: You can get new ones from Drag Specialties http://asset.lemansnet.com/static/sites/dragspecialties/flipper/2012Fatbook/#page=793 Running Light replacement lenses Drag Specialties DS-28015 large red DS-280153 large amber DS-280168 small red DS-280167 small amber Commonly known as Baron's and Mini-Baron's Thanks, I found them
