Anyone know where one can order replacement lenses.
Small one is for the lower wrap around side bag guard.
Larger one is for the lower chrome unit below the turn signal and Yamaha Lens.
Good question ive got quite a few that look like the one on the left in your pic and need to replace them im thinking about getting the kit that lets you make them youself seen it on american restoration once
I have been told you can put them in Red dye ( LIKE DYING CLOTHES) and it will turn them back to red. I also heard that you can paint them with candy red model airplane paint.
Guest scarylarry
Do you have a truckers supply where you are at? Might check with them if you do..
I replaced mine too. Got them from Cycle Parts Nation. These guys shipped fast & they fit perfect.
http://www.aftermarketcyclepartsnation.com/Drag-Specialties-BARON-TWIN-AND-BARON-MINI-TWIN-MARKER-LIGHTS-detail.htm?productid=7922788
Snoop around some of the antique car fourms and see what tricks those guys have up thier sleeves. Surely this cant be the first time someone has needed to do this on obsolete lenses.
as brake pad said they are available from JC Whitney. They have both sizes. They also used to be available from Drag Specialties maybe still are.If you just want to recolor them Eastwoods used to have a paint/dye to recolor old lenses.
I bought a spray can of red lens spray at an auto store, and sprayed the inside of the lens. Does one also spray the outside surface of the lens or just give the insde another coat?
Being that I have 22 to replace, I think the spray can is the way to go.
