GolfVenture Posted September 13, 2012 Share #1 Posted September 13, 2012 Anyone know what part this is and what it does? Link to comment Share on other sites More sharing options...
DragonRider Posted September 13, 2012 Share #2 Posted September 13, 2012 Pipe connecting the water pump to the cooling system. Link to comment Share on other sites More sharing options...
playboy Posted September 13, 2012 Share #3 Posted September 13, 2012 Naturally a 1st genner beat me to it. But they sure were slow to help :sign yeah that: Link to comment Share on other sites More sharing options...
Trader Posted September 13, 2012 Share #4 Posted September 13, 2012 Well, at least you got a good answer. I was going to say it "is" broken. And it "does" a bad job of acting as crash bar when sliding along the road Link to comment Share on other sites More sharing options...
GolfVenture Posted September 13, 2012 Author Share #5 Posted September 13, 2012 Pipe connecting the water pump to the cooling system. Anyone have one of these pipe? Link to comment Share on other sites More sharing options...
dingy Posted September 13, 2012 Share #6 Posted September 13, 2012 26H-12446-00-00 - Joint $30.46 on partshark.com in water pump tab, item #21 Gary Link to comment Share on other sites More sharing options...
GolfVenture Posted September 13, 2012 Author Share #7 Posted September 13, 2012 26H-12446-00-00 - Joint $30.46 on partshark.com in water pump tab, item #21 Gary Thanks Gary. Link to comment Share on other sites More sharing options...
wrenchrob Posted September 13, 2012 Share #8 Posted September 13, 2012 26H-12446-00-00 - Joint $30.46 on partshark.com in water pump tab, item #21 Gary thats an expensive joint! Link to comment Share on other sites More sharing options...
pmelah Posted September 13, 2012 Share #9 Posted September 13, 2012 Pipe connecting the water pump to the cooling system. Naturally a 1st genner beat me to it. But they sure were slow to help :sign yeah that: them 2nd genners are just jealous they didn't get the answer in time just shows how fast a 1st genner really are # 1 post question # 2 post 1st genner answer # 6 post 1st genner with part # and where to get it :whistling: :rotf::rotf: i love my 1st GEN and VR.org Link to comment Share on other sites More sharing options...
pmelah Posted September 13, 2012 Share #10 Posted September 13, 2012 26H-12446-00-00 - Joint $30.46 on partshark.com in water pump tab, item #21 Gary thats an expensive joint! it doubles as a crash bar hence the price:whistling::rotf: Link to comment Share on other sites More sharing options...
reddevilmedic Posted September 13, 2012 Share #11 Posted September 13, 2012 make sure you get the orings Link to comment Share on other sites More sharing options...
bongobobny Posted September 13, 2012 Share #12 Posted September 13, 2012 thats an expensive joint! Yeah man, but it's really good stuff... errr... never mind! Link to comment Share on other sites More sharing options...
saddlebum Posted September 13, 2012 Share #13 Posted September 13, 2012 Naturally a 1st genner beat me to it. :sign yeah that:On or off our steeds 1st genners are fastest. Link to comment Share on other sites More sharing options...
Trader Posted September 13, 2012 Share #14 Posted September 13, 2012 On or off our steeds 1st genners are fastest. But our wives don't always appreciate that fact! Oh Come on!! Where's your head at? I'm talking about when riding the bike!!!!!! Link to comment Share on other sites More sharing options...
KIC Posted September 13, 2012 Share #15 Posted September 13, 2012 If the one off of an 84 would work, I have probably 2 to chose from. So part Gurus.. is the 84 the same as his 91 ? Link to comment Share on other sites More sharing options...
Flyinfool Posted September 13, 2012 Share #16 Posted September 13, 2012 If the one off of an 84 would work, I have probably 2 to chose from. So part Gurus.. is the 84 the same as his 91 ? Just check your used ones real close for a tiny dent right on the outside of the bend. If the bike was ever laid down the crash bar bracket can flex back far enough to ding it and then spring back looking like lots of clearance. That tiny little ding will eventually start leaking. I ground the corner off of that bracket to give more clearance to my NEW elbow just in case the bike ever falls over on that side. Link to comment Share on other sites More sharing options...
icebrrg3rd Posted September 13, 2012 Share #17 Posted September 13, 2012 How come no-one mentioned duct tape?!? Like many, mine had that "ding" in it, I filled it up with JB Weld and painted it, now it looks just like new. -Andrew Link to comment Share on other sites More sharing options...
KIC Posted September 13, 2012 Share #18 Posted September 13, 2012 How come no-one mentioned duct tape?!? ....or SeaFoam ??????? Link to comment Share on other sites More sharing options...
MasterGuns Posted September 13, 2012 Share #19 Posted September 13, 2012 it doubles as a crash bar hence the price:whistling::rotf: Not if it's 18 oz. Link to comment Share on other sites More sharing options...
Dragonslayer Posted September 13, 2012 Share #20 Posted September 13, 2012 thats an expensive joint! And no buzz Link to comment Share on other sites More sharing options...
Dragonslayer Posted September 13, 2012 Share #21 Posted September 13, 2012 Anyone know what part this is and what it does? I've repaired them using the two part epoxy putty for plastic but, it looks like this one has too much real estate missing. Link to comment Share on other sites More sharing options...
Dragonslayer Posted September 13, 2012 Share #22 Posted September 13, 2012 If the one off of an 84 would work, I have probably 2 to chose from. So part Gurus.. is the 84 the same as his 91 ? MKI & MKII Joints are the same. Link to comment Share on other sites More sharing options...
dingy Posted September 13, 2012 Share #23 Posted September 13, 2012 Just check your used ones real close for a tiny dent right on the outside of the bend. If the bike was ever laid down the crash bar bracket can flex back far enough to ding it and then spring back looking like lots of clearance. That tiny little ding will eventually start leaking. I ground the corner off of that bracket to give more clearance to my NEW elbow just in case the bike ever falls over on that side. I find that tiny little ding comment to be a form of sexual harassment. Not to mention TMI !! Gary Link to comment Share on other sites More sharing options...
Trader Posted September 13, 2012 Share #24 Posted September 13, 2012 It's got the ding! Let me know if this is OK....yours for the cost of shipping Link to comment Share on other sites More sharing options...
reddevilmedic Posted September 13, 2012 Share #25 Posted September 13, 2012 he already has one that bends to the left...he needs one that bends right! didnt you read the TSB? Link to comment Share on other sites More sharing options...
