Cougar Posted September 7, 2012 #1 Posted September 7, 2012 I just put on my second clearview that I found for a awesome price last week. it had been stored for about 2 years in the original box. My Question is will Goo Gone hurt the windshield? I mounted it and started to peel off the plastic covering they put on. but from sitting so long. I have a small area about the size of a grape fruit were it left some sticky stuff. Thanks for Ideas. Just wanted to check before I tried it. Otherwise the shield is in perfect shape. Jeff
djh3 Posted September 7, 2012 #2 Posted September 7, 2012 I wouldnt use it. I would opt for some soapy water like Dawn or the like. I would be afraid that the GOO Gone would have something in it that might harm the coating and cause it to haze. I would try WD 40 before that.
Cougar Posted September 7, 2012 Author #3 Posted September 7, 2012 Yeah didn't think of that.. maybe I will try some warm soapy water or wd40 thanks
Cougar Posted September 7, 2012 Author #4 Posted September 7, 2012 I did find this for residue left on flat screen TV's Mix 1 tablespoon of isopropyl alcohol with 3 to 4 tablespoons of water. For very sticky residues, you can use up to 50 percent isopropyl alcohol. To make this combine 2 tablespoons isopropyl alcohol with 4 tablespoons of water. 2Dip a soft, clean and lint-free cloth into the isopropyl alcohol and water solution. You could use a microfiber cloth or the type of cloth used for cleaning eyeglasses. Wring out any excess solution.
BlueVenture87 Posted September 8, 2012 #5 Posted September 8, 2012 I use goo gone on computer plastics all the time without issue, if in doubt try it on the windshield below the trim line. I bet you'll have no problems with it.
Wrench Posted September 8, 2012 #6 Posted September 8, 2012 I'm not sure about the Goo-gone either. Before I delivered my Roadstar to it's new owner I had a couple of "politically incorrect" decals that I figured I'd better take off. I had put one over the original cheesy orange safety sticker that came on the Silverado windshield because I couldn't get it off. When I peeled the sticker off a little bit of the orange one came off leaving it looking like crap. I took some duct tape and covered the rest of the sticker, then rubbed it down pretty hard with my hand. Then I started pulling the duct tape back against itself, voila', the old sticker and the adhesive came right off. I had tried just about everything to remove it when I bought the bike and didn't find anything else that would work. You also might try warming it just a little with a hair dryer so the film isn't so brittle too. Good luck!
Eck Posted September 8, 2012 #7 Posted September 8, 2012 WD 40 would be my choice, then some car wash soap and water to wash the WD 40 off.
van avery Posted September 8, 2012 #8 Posted September 8, 2012 Might try peanut butter. Many times the oil in it will soften the adhesive.
Cougar Posted September 8, 2012 Author #9 Posted September 8, 2012 peanut butter now that's differant.
Cougar Posted September 8, 2012 Author #10 Posted September 8, 2012 Thanks guys,, still kicking around what I should use. I have to tackle this soon this morn. It seems that WD40 should not hurt anything. So many decisions The worst part is that this sticky of course in right in my line of site. go figure. It is also going to be interesting to see how clear vers. tinted will be for me after 4 years. as I ride to work in the morning in the dark. Jeff
Hazenson Posted September 8, 2012 #11 Posted September 8, 2012 actually Peanut butter has a bunch of uses like that, can be used for getting tape and other sticky stuff off of items. wife found that info in a book and It sounded crazy but it does work. But ya need to let it set for a while to let the oil work
Cougar Posted September 8, 2012 Author #12 Posted September 8, 2012 OK, Now I have to try Peanut Butter FIRST! LOL will report back soon, I Better use CREAMY Skippy Then !
Snaggletooth Posted September 8, 2012 #13 Posted September 8, 2012 Used to use peanut butter to get gum out of my daughters hair. It does break down the sticky stuff. Mike
Cougar Posted September 8, 2012 Author #14 Posted September 8, 2012 But will it break down the shinny finish of the new windshield? maybe I should mix WD 40 and Peanut Butter together Ummm
Cougar Posted September 8, 2012 Author #16 Posted September 8, 2012 Well so far hanging out in the garage.... peanut butter has no effect on this residue and soapy water has no effect... come to find out I can not find my can of WD40 so waiting for the store to open to run down and get ANOTHER can... when I get it I am sure I will find my old can ! I will give a full report soon !!
alwrmcusn Posted September 8, 2012 #17 Posted September 8, 2012 I used Goo Gone to remove the residue left on my tank when I removed the government warning sticker. I also used it on my fair to remove the gummy residue when I removed the eye brows. It has not hurt the paint or finish. .....Note in the photo below that the government warning stick is on the tank, it has been removed for about two years now.
Cougar Posted September 8, 2012 Author #18 Posted September 8, 2012 The test results are in....... WD40 worked like a charm Then finished up with Novus Cleaner.. PERFECT Thanks Gang for your help ! My garage smells like peanut butter now Pretty sad when WD40 cost less then peanut butter. Jeff
Eck Posted September 8, 2012 #19 Posted September 8, 2012 The test results are in....... Pretty sad when WD40 cost less then peanut butter. Jeff, does this mean your going try the WD 40 on a sandwich?
dacheedah Posted September 9, 2012 #21 Posted September 9, 2012 And a thread where Seafoam wasn't mentioned, oops
Cougar Posted September 9, 2012 Author #22 Posted September 9, 2012 yeah, why didnt you guys tell me about sea foam
SilvrT Posted September 9, 2012 #23 Posted September 9, 2012 I use peanut butter to clean my hands after working on the scoot ... ya don't even need to wash it off .... just grab a slice of bread and ..... LUNCH!
djh3 Posted September 9, 2012 #25 Posted September 9, 2012 Glad it worked out. Its some pretty handy stuff, we use to get it by the 5 gal in the shop when I was in the Air Force. Now that your done and dont need it Im sure the other can will show up.
