  Wizard765 said:
Hi All you guys with parts bikes... I was wondering if anyone has a set of forks for a MKII they would be willing to part with? Got a project to work on...
Do you need complete set or just lower outer tubes?
I have a set of lowers I could part with if I do something a little different for my project.
Gary
Actually I need a complete set. the inner tubes on the bike are pitted or damaged in the area that goes past the seals. One of the outer tubes it looks like someone tried to drill out the bolt at the bottom and slipped off so there is a hole in the area that it seals.. Carl came up with some "O" rings and it appears to be holding at the moment but not sure for how long etc..
