If you used a converter and not an isolator (isolator connects to the battery, converter doesn't) then the hazard lights won't work unless the engine is running. Think it has to do with how much power it takes to turn the lights on (remember, without an isolator connected to the battery, the connections have to split the power to all the lights).
Even without a trailer, the bike's hazard lights will not work unless the ignition key is turned on (engine doesn't have to be running but key must be all the way on - when you would normally hit the starter button).
yea thats what I read b4.... i have old timer moments now and then... oh by the way i ran out to garage & STARTED THE BIKE AND WAAALAAAA they worked :D
I had posted the same thing in the other thread.
Over the Winter I'll be replacing the converter with an isolator. If for no other reason than being able to have the trailer 4-ways working if the engine won't.
I looked for an isolator at the parts place today but they didn't have one.... if they did I didn't know what it was ... lol
