Hi everyone, just completed a 4k ride with the R1 upgrade, Vmax rotors, stainless lines and EBC HH pads. Wow, what a diff. However, I can really notice the limitations of the stock, front master cylinder when leaning on them. What's the upgrade for the master cylinder?
Also, has anybody come up with a fork spring solution other than the progs? I just put them on before the trip (block off plates, AD's removed) and once most of the oil blew passed the seals, they mellowed a little. Still, I'm not liking them at all. Way too stiff. I look down at the forks and unless I really lean on them or hit a huge bump, they don't compress at all! I put progs on my 92' BMW K75 back in 2006 and had the exact same experience. I have no spacers installed for preload at all.
I would think a two stage spring would be awesome. Perhaps cutting the progs down and adding something softer in the bottom? Has anybody come up with a better solution? Perhaps I don't have them dialed in correctly but even with no oil at all they're too stiff. I was using 10wt. Also, I'm sure it's not the weight of the bike. I had the bike and trailer fully laden weighed on our last night: Bike = 933lbs, trailer = 435lb. Tounge weight is around 20lbs. I'm 190 and my wife is 145. Still seemed incredibly rigid.
Thanks everyone! Great forum!
Edited by jimmyenglish
forgot to add stuff
I also would like to know of a front brake master upgrade . . . So far as your Progressives, my only thought is that something is not assembled correctly. I have Progressives on three bikes and all have done exactly as advertised. There is better - softer small bump action that progressively gets stiffer. My VR has been put on a diet by removing a number of chrome farkles. The total weight of me and the VR is probably about the same as you and yours. I am running 7awg fork oil and the anti-dives are disconnected. The spacer that came with the springs was substituted for the stock metal sleeve and the forks work very well. Could the fork assembly be binding?
:confused24:
When Rocket put my progressives in, we talked about ride and he suggested if I wanted a softer ride we should try not putting their spacer in, or finding something shorter so it doesnt have as much preload. Mine have been running great for about 4 years now since the owrk was done not using any spacer. (But ive noticed this year the ride is getting a bit soft, so I may have to find something to space it a bit).
Brian
  • 7 years later...
  bongobobny said:
For the 2nd gen's it is a 14mm bore master, and it would probably work with 1st gens as well...
Hay Guys, I just tried to rebuild my front break master cylinder on my 1988. The K&L kit that was advertised to fit (232-4146) is for a 16 mm bore and my 1988 has a 14 mm bore. Does anyone know what the correct K&L kit number is. They are readily available so it would be convent to just order the correct kit but they do not list the size.
Maybe I will just order the kit for the new Venture.
Ok after a bit more research for anyone interested. I got on a site that sells OEM parts and got a part number for the rebuild kit. 4H7-W0041-50-00. On another site they had a photo of the kit that is listed as the correct size for the 1988. It has a ruler laid out below it and it shows the rubber ring that is approximately the size of the cylinder bore. It was just about 1/2 inch so it is likely for the 14mm bore cylinder. I took that OEM part # and put into the search bar for Amazon and low and behold up came the part but it is listed for a several ATVS over several years. It does list the part number so it is safe to say it should work. $22.95 with free shipping. Now lets discuss what other master cylinder will work on these handle bars that is 16mm since I think that might be better for a delinked system that I put together. I can also suggest not staking 2 lines on the master cylinder. Better to run just one line and split it down below. The two lines took up too much room up top.
Edited by Geobob
