A couple of weeks ago, Dingy posted some great 1st. Gen service bulletins. One of the items concerned the bolts that join the right lower section to the main frame. This is the section that you remove to pull the motor. While I was working on the 89 yesterday, I thught of this proceedure and decided to make sure mine were tight. I pulled the right footpeg bracket, and tightend the bolts.....mine were about 1/4-1/3 turn loose. I also checked the forward bolts, and 1 of them was a little loose. BTW, Yammie suggested that they'd be checked every time the bike was in for service. I didn't think the bolts were so loose that they'd cause a problem, but today I noticed that the bike seems to turn a bit better.
Thanks Gary!!
Frank D.
The webpage cannot be found
Most likely causes:
  • There might be a typing error in the address.
  • If you clicked on a link, it may be out of date
