Systems eight years old with severe Trojan. Thinking of new one. Dell or where? Had pretty good luck with Dell. I do not know enough about the things to fix this one Black screen does not give you much to work with.
Reformat and reload or buy a new back to school if it will do what you want. I have seen some good prices, just because you ride a first gen doesn't mean u gotta use an 8088, lol
I could build you a new computer Dan, easy as pie for me. Might even save you a few $$, but I'd prefer you pick it up instead of me trying to ship it. The other option is getting a new hard drive and loading your restore cds on it then installing it in your computer.
Dan,
Here is my recommendation:
CategoryPartURLPrice CPUIntel 3.4GHz Core i7-2600K
www.intel.com$317 MotherboardGigabyte GA-Z68X-UD7-B3
www.gigabyte.com$350
GPU3x EVGA GeForce GTX 580 Superclocked
www.evga.com$1,557 ($519 each)
CaseCooler Master Cosmos II Prototype
www.coolermaster-usa.com$350
RAMCorsair 16GB Vengeance
www.corsair.com
$180 PSUSilverstone Strider ST1500
www.silverstonetek.com
$380
CoolerCorsair Hydro Series H100
www.corsair.com
$120
SSD2x 240GB OCZ Vertex 3
www.ocztechnology.com
$1080 ($540 each)
HDD 3x 3TB Seagate Barracuda XT
www.seagate.com
$600 ($200 each)
ODDPlextor B940SA
www.plextor.com$169 SpeakersCorsair SP2500
www.corsair.com$250 MouseCyborg R.A.T. 9
www.cyborggaming.com
$130
Keyboard Razer BlackWidow Ultimate
www.razerzone.com
$80
Monitor3x NEC PA301W
www.necdisplay.com$6900 ($2300 each)
OSMicrosoft Windows 7 Professional
www.microsoft.com
$125 Total Cost $12,588
How have you arrived at conclusion it is a trojan, if you have not gotten any video yet?
Just trying to understand process here..
For about $1500, I can send you specs on a high powered computer that GAwildcat helped me with about six months ago. It will probably be able to keep up with you. Quad core, 16 gig ram. Nice mid range graphics card.
I think it mostly came from tigerdirect.
Gary
Dan, just get an Apple Mac....no, wait..that would be just like you buying a 2nd gen. :smile5:
Gary
Gary: Dan doesn't need that high tech of a system lol, you had special needs that required a specialized build. I could build Dan a much cheaper system that would meet his needs easily. Looking now at builds to see what I could do.
I could put a smaller harddrive in the system for a bit cheaper, but the most you may save is $20. I didn't add a monitor, keyboard and mouse, unless Dan has a flat panel monitor, he would need one of those too. Also, everything on this list can be found at newegg.
ASUS M4A88T-V EVO AM3 AMD 880G HDMI ATX AMD Motherboard
Model #:M4A88T-V EVO
Item #:N82E16813131827
Return Policy:Standard Return Policy
In Stock
$89.99
AMD Athlon II X4 640 Propus 3.0GHz Socket AM3 95W Quad-Core Desktop Processor ADX640WFGMBOX
Model #:ADX640WFGMBOX
Item #:N82E16819103871
Return Policy:CPU Replacement Only Return Policy
In Stock
$99.99
G.SKILL Value Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1333 (PC3 10600) Desktop Memory Model F3-10600CL9D-8GBNT
Model #:F3-10600CL9D-8GBNT
Item #:N82E16820231422
Return Policy:Memory Standard Return Policy
In Stock
$39.99 $39.99
LOGISYS Computer Area 51 CS51WBK Black Steel ATX Mid Tower Computer Case 480W Power Supply
Model #:CS51WBK
Item #:N82E16811148030
In Stock
$49.99 -$10.00 Instant $39.99
Western Digital Caviar Green WDBAAY0010HNC-NRSN 1TB SATA 3.0Gb/s 3.5" Internal Hard Drive -Bare Drive
Model #:WDBAAY0010HNC-NRSN
Item #:N82E16822136776
In Stock
Note (Add)
$109.99 -$10.00 Instant $99.99
ASUS DRW-24B1ST/BLK/B/AS Black SATA 24X DVD Burner - Bulk - OEM
Model #:DRW-24B1ST/BLK/B/AS
Item #:N82E16827135204
In Stock
Note (Add)
$19.99 $19.99
Microsoft Windows 7 Home Premium SP1 64-bit - OEM
Model #:GFC-02050
Item #:N82E16832116986
Return Policy:Software Standard Return Policy
In Stock
$99.99 $99.99
Subtotal: $489.93
Don't spend more than $150.00 for another computer. I got my last two for less with Intel Core 2 Duo and 80 gig hard drive. Been using them for years... :2cents:
About 1 year ago I purchased a Gateway at Staples, $300 on sale, 1T hard drive and 4 gig of ram (I think). Nothing special but it does what I want it to do and has had no issues in the time I have owned it. Depending on what you do with your computer this might be good enough.
Need to replace the hard drive in my 8 year old Dell, I put in a refurbished (probably a mistake) 320 gig Western Digital a year ago and it has died. Anyone have a recommendation on what to to install this time? :confused24:
Just go get a new hard drive, say on newegg or tigerdirect. Right now I prefer western digital drives over all others. I don't trust refurb hard drives ever. Basically if it's a refurb, it's been inspected and may or may not be ok. It's a roll of the dice. With a new drive you have a 3-5 yr warranty on replacement.
Guest tx2sturgis
Seriously, all you really need to do is boot from a Live CD such as Linux Mint or Ubuntu. $10 for the disc.
Of course if the hard drive or other component has actually failed, then that will have to be replaced first.
Gonna side with the "less is more" crowd on this one. As a recovering tech geek / former system tech-network manager-administrator-general whipping post there is no need to over buy or over build.
Hard to go wrong now with "off the rack" from Tiger Direct. Unless you are a hard core gamer, multi tasking multi monitor business fanatic, or CAD user excess RAM and processor power is a waste of money. Then add in the cooling and other extra expense and it makes no sense. UNLESS you REALLY use it.
I am still using my last build. 2.8 gig dual core processor (AMD BTW) and 4 gig of DDR 3 RAM, vid card with 1 gig DDR 3 and serial ATA drives. It must be 4 years old now at least. AN AMD 5600+ was one step removed from bleeding edge at the time. It still pulls a Windows Experience Index of 5.7. The minimum hold back factor are the years old SATA hard disks. Everything else runs in the low to mid 6 range. I chose well at the time. The main board I have is still sold and used. At least it was early this year when I needed to buy a new main board driver CD.
If the PC did what you wanted it to do well enough to make you satisfied, put a new hard drive in it. A stomping big one and the fastest you current bus will utilize. And get another few years from it and spend money where it is important. Beer and bikes.
Getting off the :soapbox:now.
Guest tx2sturgis
  JohnT said:
Gonna side with the "less is more" crowd on this one. As a recovering tech geek / former system tech-network manager-administrator-general whipping post there is no need to over buy or over build................ And get another few years from it and spend money where it is important. Beer and bikes.
I love the geeky-yet-common-sense answer here. This guy has it right.
Now...John...would you PLEASE post pics of that 80 GS1100??? I had a 1980 GS 750E and I never got any good pics of it the entire time I owned it. At the time, I was dating a beautiful blonde and I saw NO reason to spend money on film and prints of the bike when I could take pictures of her.
Well thats another story. Anyway, mine was the dark blue color.
How about sharing?
Hijack the thread if we must, but I'd sure like to see that bike! :happy34:
We would rather see pics of the blond..........
As mentioned, unless you are doing something in 3D then a low end computer will serve you well for many years to come.
Where are you gong to find a key punch machine and card reader?:confused24:
Seriously though, you can get trojans and crap on a brand new computer too. If the current one is good enough just clean it up.
Dan, you had it right, Take the nasty thing out back and put a hole in it. It's 8 YEARS OLD! !:doh:
I'm with Skid on this one. For what your doing on a computer you can easily get one for under $500. Heck you can get a good laptop for that...If your wife has one hooked up to a printer that's exactly the route I'd go. :confused24:
Gaurenteed his old one will not/does not have RAM capacity or exapndability and that will really slow it down when loading newer web pages
Edited by CaptainJoe
Dell laptops SUCK, HP or Toshiba is the way to go on laptops. I don't even consider desktops viable anymore with the prices of laptops being within $200 of same spec laptop. There are some situations with expansion cards where laptops don't do as well but not too many.
I worked in disk drive industry most of my career. Do yourselves a favor and buy from HP, Dell etc vs aftermarket. They certify the top performing heads and platters. Aftermarket gets whatever is left. You pay about $15 more but worth it.
Did I mention DELL laptops SUCK!!!!!!
I had rebooted it when I got about 30 or so little boxes popping up and I did a Microsoft security essentials scan and it found a severe trogan and I set to remove it and it said to reboot for the changes to take place so I rebooted and that's when the black screen with blinking cursor showed up.
Malware bytes software is free and will clean out stuff that Norton and avg AntiVirus software cant. You first need to be able to boot to windows however, try F8 during boot and select safe mode.
Dan,Your hosed at this point. If you are not a computer hobbyist. The virus has sunk in deep at this point. The safest way to go is to buy a new hard drive and then reinstall the "operating System" that came with the computer. On a side note Skid has the right idea. If you just surf and send emails etc. You dont need to spend more that 200.00 for a new puter. Do you have a "Micro Center" near you? they have good deals. Also, you could "f-disk" your hard drive, and then "reformat" and then install the OS with disks you have on hand.If this stuff is greek to you, you will need a computer guru friend to do it. Sorry buddy I wish I was closer... http://www.microcenter.com/search/search_results.phtml?page=3&N=4294967292&Ns=P_RetailPrice&Nso=Ascending
