Royal Venturer Posted August 17, 2012 Posted August 17, 2012 (edited) Been awhile since I've been on the forum. Been around since late 2004 when this all started. Have a 2005 RSV Speedometer, odometer, trip meters and and gas gauge all work. Cept at night its all in the dark. heard tell a new unit is $1K....can this be right and is there other solution. I've not pulled the fairing yet. Thought I'd get some feedback from one and all first. Also is there a fuse just for the LCD illumination back segments? thanks Jim Edited August 17, 2012 by Royal Venturer
eusa1 Posted August 17, 2012 Posted August 17, 2012 I have replaced 2 speedometers on friends rsv's and they were both 2005 models that the back lighting failed
BradT Posted August 17, 2012 Posted August 17, 2012 About 800 bucks. Ouch hope that is not the problem and I would be looking into other ideas. BRad
Royal Venturer Posted August 17, 2012 Author Posted August 17, 2012 like a miners lite on my helmet!!! I'll do some research about lcd back lighting, see if there is other solutions or a alternatives. 800-1000 bucks for a light, good friggn grieve, that's robbery.
crowrod Posted August 19, 2012 Posted August 19, 2012 May be you could use a ten strand optic fiber bundle,looks like there is a small shelf on the lower section of the speedo you might mount them thru. just a thought. also doubt if it would be very expensive!
