jimc1031 Posted August 15, 2012 #1 Posted August 15, 2012 Hi Venture Friends I am a newbie to Venture rider I just bought a 1987 Venture 1300_ I bought it cheap and of course Has its problems . All the diaphyrams in carbs are busted no problems with handling this problems. MY BIG CONCERN IS THE TRANSMISSION-'THE REAR WHEEL WAS JUST STUCK ON . I REMOVE WHEEL TO TEST DIFFERENTIAL ETC--FOUND LOTS OF PLAY IN TRANS. I COULD MOVE DRIVE SHAFT APPROX 90 degrees back and forth except for 5th gear in which was nor mal I drain oil no signs of metal in oil . My question what should back lash be when rotating driveshaft- WHY IS IT SO MUCH PLAY IN 1 thru 4 but. 5th to me is nornmal Thanks. Jim C. Carson City. Nevada:bacp
Squeeze Posted August 25, 2012 #2 Posted August 25, 2012 As long as you don't hear any bad Sounds from it, the Play seems to be normal for me.
