CaptainJoe Posted August 15, 2012 #1 Posted August 15, 2012 Need a second gen seat. Don't need the foam or the cover just the frame.... Experimenting with an idea I had .
CaptainJoe Posted August 17, 2012 Author #2 Posted August 17, 2012 Bump???????????? I'm not lookiNg for GIVE AWAY...(would be nice but I'm realistic) Will pay a reasonable price, but Im taking the vinyl and foam off anyway.
Cougar Posted August 17, 2012 #3 Posted August 17, 2012 Joe, let me take a looksy over the weekend in the shed and see if I still have a MM seat in there. not sure if its still there dont get your hopes up yet.
KIC Posted August 18, 2012 #4 Posted August 18, 2012 Sounds like you are customizing a seat. I helped my friend customize his 2nd Gen seat for CHRISTmas last year...so... if you need some help, here is my handi work:
CaptainJoe Posted August 18, 2012 Author #5 Posted August 18, 2012 Cougar, Thanks let me know. Kic, no thanks fella.... LOL I'm going to modify a second gen seat by cutting away portions of the bottom and installing a waterproof 90 CFM fan. Then will streech a breathable top across using different materials so entire top surface is porous/breathable. Going to be an interesting challange doing the top as it must be comfortable and look good. And NO IT'S NOT GOING TO BE PINK!
Freebird Posted August 18, 2012 #6 Posted August 18, 2012 Is this going to be for cold weather? I can see where that MIGHT work if you are trying to warm the seat but if you attempting to cool a seat, it just seems that you are going to blowing engine heat into it.
CaptainJoe Posted August 18, 2012 Author #7 Posted August 18, 2012 Not if I place a thin aluminum plate under the fan so that it has to pull air in from the sides... concept borrowed from laptop cooler pad.... But with slideeable areas I can see where you could also heat it Thanks Freebird
Freebird Posted August 18, 2012 #8 Posted August 18, 2012 Well good luck. Let us know how it works out
OB-1 Posted August 18, 2012 #9 Posted August 18, 2012 captainjoe said: Not if I place a thin aluminum plate under the fan so that it has to pull air in from the sides... concept borrowed from laptop cooler pad.... But with slideeable areas I can see where you could also heat it Thanks Freebird Better put some bug screens on it too. Ya wouldn't want to pull in any hornets.
Cougar Posted August 19, 2012 #10 Posted August 19, 2012 No sign of the seat Caption !! gave it a shot tho.. good luck on your project ! Jeff
dacheedah Posted August 19, 2012 #11 Posted August 19, 2012 oh u could use dampers on those baffles, winter mode and summer mode. Sounds like an awesome idea, keep us updated on how your beta testing is goin on your butta. . .
wrenchrob Posted August 19, 2012 #12 Posted August 19, 2012 I want to try something like this for a winter project. I was thinking about trying to install a TED (thermo-electric device). A TED can be found in some newer vehicles used to cool the seats. I work for a Ford dealer and am waiting to hopefully get one from a warranty return to try so as to try and keep costs to a minimum in case this project fails.
