soyer38301 Posted August 3, 2012 #1 Posted August 3, 2012 I am feeling rather foolish to have to ask this -- but I don't have a Clymers manual for my 85 Royale as of yet... I need to check the trany fluid level -- and my feeble brain can't figure it out. I had noticed some leakage about a week and a half ago after bringing the bike up to where I am staying during the week. It was on the right side dripping off the exhaust pipe -- which was strange since it was leaning left on the kick stand. It did not leak directly after parking it, but a few days later after having sat without being run. It has since stopped the leaking... I do have it on the center stand now and the engine oil is very near the top line in the sight glass so I don't think it was engine oil unless that had been over filled. The coolant is where it should be (don't think it was coolant anyway) so the only thing left is the transmission... Would someone point a quasi weekend mechanic in the right direction? Thanks Scott
Trader Posted August 3, 2012 #2 Posted August 3, 2012 there is not a separate transmission fluid. All engine oil except for rear end pumpkin,
Condor Posted August 3, 2012 #3 Posted August 3, 2012 I'd try reducing the crank case oil to the middle of the lines on the sight glass while on the center stand. With your oil at the top line it's boarder line overfull....
Flyinfool Posted August 3, 2012 #4 Posted August 3, 2012 Couple of ideas. 1. The oil level should be no higher than the center of the sight glass when on the center stand and on level ground. 2. The engine and transmission share the same oil system, there is no separation between engine and trany. 3. On the right side where you describe is the reservoir and master cylinder for the rear brake. Are you sure it was not brake fluid leaking?
soyer38301 Posted August 3, 2012 Author #5 Posted August 3, 2012 Thank you gents -- guess that explains why I could not find how to check it lol... I'll drain some of the oil out and see what happens. Scott
friesman Posted August 4, 2012 #6 Posted August 4, 2012 (edited) yep my 85 hates being more than 1/2 way up the sight glass, if it is mine spits it out of the breather tube that drops down just in front of the back tire perhaps your tube was over the exhaust when it puked out the oil. a manual is available in the tech section here. and ill look for a link from the Euro Venture group that has manuals as well as the service manuals and post it here for you. Brian http://www.yamahaventure.nl/en/usermanuals.html Edited August 4, 2012 by friesman added link
