The PO welded a piece of 1.5"ID square stock to the bottom of the Bustec hitch on the '91. The square measures 2" on the outside. I can't find a ball mount anywhere. One of the local stores did give me a 1 3/16" drawbar because they didn't even have it listed in inventory.... and it was around christmas... :), but it's pretty sloppy, and is designed to fit into a 1.25" receiver. I've been all over the internet trying to find something, but so far nada.... So.... do they even make a 1.5" receiver?? I guess the options I have would be:
Condor,
I have no idea where you can purchase 1.5 square steel tubeing...but if I were to locate some, how long of a piece do you need??
You can buy about any size square stock you want, just have to go to the right place.
I would be more inclined to modify the receiver so that it fit a standard insert.
Wonder what the previous owner was using?
Jerry
  Eck said:
Condor,
the tubing welded to the hitch is 1.5" acrossed on the inside and 2" acrossed on the outside. I not sure if they go by the inside or the outside when refering to it??. Pro'bly 12" should do. If it isn't long enough I can always use the stretcher..... :whistling::) I have a place here in town, Blue Collar Supply, that deals in surplus metals. I haven't given them a try yet.
Jerry
That may be the way I end up going Jerry, and probably the cheapest too.....
Hey Condor,
I just stopped in at one of the local auto parts stores here in Huntsville, (Auto Zone) and they have 1.5 inch recievers on the shelf...
Just a thought in that you might want to stop at a local auto store and see what they have ....and you can ask on WHAT they can get from thier hitch people..
any RV store can get you one with any size drop , they come in 9 in. and 12 in. you can ck. campingworld.com and order it on line , you need a 1 1/2 in. ball mount .
thom
thom
There's a couple of large RV stores here in town and I'll check them out next week. They sorta slipped my mind.... Thanks for the reminder. I would have thought I'd have been able to find at least one on the net somewhere??? I hope the stores have them...
  flb_78 said:
Wrong size. I guess I need 2"OD according to the drawing. That tubing's 1.5" outside. I need the 1.5" on the inside. I checked their other auction listings and their too expensive. I'll keep it in mind though as I might change the receiver instead of making a drawbar fit if I can't find one.
