Well looking for some info guys. If we can get some info on the measurments for the valve tool I have a very talented person that may attempt to make a couple if it wouldnt end up costing more than just buying one. Here is a pic of the dimensions we need.
Why Stainless Gary? Will it get hardened and passivated?
One of the guys I talked to about making this was leaning towards the 17-4. Said it was fairly machinable, then could be hardened to get a decent strength.
I didn't pursue this due to the high quotes I was getting and the problems that some have had even with the stock Yamaha tool breaking. I needed to order a 100 at a time to get a price in the high 30's. Didn't seem worth the risk for the low volume that could be sold.
And the valve tool has a much more limited target group than the steering bearing wrench I sell. That wrench fits about a hundred Yamaha models and is a much more likely tool for the average guy to want than a valve tool.
Gary
So Bob does that answer our questions? LOL I know you were cautious on the heat treat. Looking more like its buy one huh?
well, for a one pice deal yes, as gary had mentioned the initial cost of one is killer high. If we were doing 10 or more we could get the price down to a reasonable $40.00 or so. I have not however seen mention of 8 more people wanting one.
Gary, any one over on the vmax forum use these? Maybe you could hawk a couple over there? I would prefer making them from tool steel instead of stainless, the hardness/brittleness is more predictable than SS.
OK one of the pictures ther confuses me as I have not yet done valves on this motor yet. This gizmo fits under the cam and against the bucket of 2 adjoining cyl. Do you turn the motor over to get it in place or somehow grab the poor nubby end that is there and rotate it to force the buckets down. On the FJ 1200 the tool bolts down to a cam cap and a "finger" pushes the bucket down sort of like the pic with the piece of all thread and flat metal.
The cam has a hex shape made into it that engages the tool. You rotate the crankshaft to pull the tool around - depressing the buckets.
It's not adjoining cylinders though. It's two valves on the same cylinder. The Venture has 2 intake and 2 exhaust valves per cylinder.
OK yup forgot that dual valve thing. So to get tool out you rotate motor backwards? Or the tool turns thru?
Also Bob I put a note out on another Venture fourm I'm on to see if there is any interest.
OH my I know on the FJ motor if you turned it backwards you had to then rotate forward as your cams were not actually where the timing is set up. I guess it dont matter as your not running it that way and the plugs are out. Well I'm guessing the plugs are out to make it easier to turn thru. Then turn motor thru once or twice correct way before putting plugs in and firing up. Just seems an odd way to do things imop.
By the way the other post I put out for buyers.
Hope I'm not highjacking this thread TOOOO much:whistling:
I'm totally ignorant of this procedure...
and don't have experience as a mechanic on the internal parts so could some one help me understand a bit more?
During the rotation of the cam some of the lobes would be engaged, pressing against the valve stems with the valves partially open or closed.
Some lobes would be totally free at any given time.
So wouldn't you have to use the tool to rotate the cam to check clearances?
or would you just use the rear wheel?
Are there any good pictures of the shims etc....the pictures in the online manual are so dark you can't really see any details.
I would be interested in a tool....and lots of help when the time comes..but I'm brave (or stupid) enough that I'm willing to try just about anything. I mean...what can go wrong right?:whistling:
Ah, a man after my own heart!
I am in !! :)
OK, I have a couple of stupid questions..... Why does this thing need to be hardened, or made out of steel?? It just compresses the valve spring, who cares how accurate it compresses them?? How many times will it be used in it's lifetime?? Also why can't it be made out of easier to machine T-6 aluminum??? Heck, I bet it could be made out of plastic... :confused07:
I read of someone breaking one of these, unknown as to why or what caused the malfunction but, there would be a reasonable reason.
If there were more than just hearsay about one tool breaking it might be a good reason, but my stupid questions still stand... MOF I can't imagine how anyone could have broken one of these tools unless it was misused?? or there was a big flaw in the casting???
It was not just rumor.
The ones I made were out of 1045 steel.
The first one did break in half. Not sure if it is because it was to weak or user error.
I have since added more metal to the weak area.
There has not yet been a chance to try the newest version.
I have read about a few of the OEM ones breaking to.
That is why everyone that has a shim kit to loan out has the disclaimer that if you break the tool you replace it.
I think that even 7075-T6 aluminum will be to soft and may not even last thru one cycle of replacing all of the shims before it wears out on the ramps. Aluminum rubbing on sharp edges of hardened steel does not last long. The cost of the tool is not in the material, it is in the labor and tooling. It would take almost as long for me to make one out of aluminum as it did out of steel.
There is actually a lot of force on that poor little tool.
