Tkosanic Posted August 10, 2012 Author #26 Posted August 10, 2012 (edited) The carbs have been cleaned thoroughly. I checked spark and all but that one have spark. the plug is coming out with gas on it. The tank was drained and cleaned and it has premium in it now. I swapped the connections for the coil for the back right cylinder and it had spark for a few revs then quit. Edited August 10, 2012 by Tkosanic
Power Trippin Posted August 10, 2012 #27 Posted August 10, 2012 Try swapping the plug wire from the dead cyl to one that does have spark. If there is still no spark on the same cyl, try swapping spark plugs, if the same cyl still does not have spark, it is either a bad coil, tci, or wiring issue.
Tkosanic Posted August 11, 2012 Author #28 Posted August 11, 2012 I swapped the plug wire...No change. Then I swapped the Connectors for the coils....Change. That coil is good. So all my coils are good. Brand new iridium plugs. I cleaned the connections on the TCI with electrical cleaner and a wire brush. Where is my problem? I am hoping not the TCI.
Trader Posted August 11, 2012 #29 Posted August 11, 2012 Tkosanic said: I swapped the plug wire...No change. Then I swapped the Connectors for the coils....Change. That coil is good. So all my coils are good. Brand new iridium plugs. I cleaned the connections on the TCI with electrical cleaner and a wire brush. Where is my problem? I am hoping not the TCI. easy answer is to find a member close by with a good TCI and try swapping it out. Long answer is that there is a thread on here explaining procedure to test TCI. I'm lousy at electrics...but reading your last post sounds like the coil is NOT good.
