Well it looks like I am going to be sidelined at least 3 months or more so I am thinking I should do some serious maintenance on the bikes. So here is what I am thinking:
Do the valve check, both bikes are way over due
Check the clutches in both bikes maybe go ahead and upgrade the springs
Check and adjust steering head bearings
Change and Bleed Clutch and Brakes
Flush cooling systems
Check all the hoses and rubber
Change oil in one just did the other
Set the other one up to tow a trailer also
Finish the solo mod on the one and paint it
Lube everything that should be lubed.
Any other ideas?
eat lots of ice cream :D and get better soon if there is something wrong with you.:confused24:
Can't have the ice cream :bang head: part of the reason I am in the shape I am. I had a small circulatory issue of my head that caused damage to the muscles and nerves in my left eye so I now have double vision doc says I may see improvement anywhere from 6 weeks to 3 months if it is not permanent.
Sorry to hear this Joe. Three months is a long time but you will make it. I was off the bike from January to April of this year, after having hip surgery. If I can make it you can too. It sounds like you have enough bike projects to keep you occupied for a while.
Earl
