Is it a easy to add a air pump for the mono air shock on the RSTD? Should I get one from a RSV or is there an after market set up. Id just like the convenience of adding air on the fly rather than stopping at gas station to add air.
The RSV doesn't have a pump for the air shock. The older Gen1 VR did.
Buy a $30 Harley no loss hand pump and carry it in a saddle bag. Its small and takes 1 minute to give the shock a shot of air.
I agree and you really shouldn't be using the air pump at the gas station anyway. You stand a real chance of blowing the seal in your shock. Most of us use the small Progressive hand pump. Quick and easy.
I'm a new owner of a '06 RSTD. I bought the Progressive Suspension pump with a range from 0-60 psi. It takes about five minutes to air up both ends and from what I can tell, there was absolutely NO air loss while I was removing the pump. Airing the rear up to 40 psi resulted in a noticeable improvement in handling. There was about 10 psi when I started. I am keeping the front at 4-5 psi. The ride is somewhat firm but definitely NOT harsh or rough at these pressures.
Davo
The small hand pump works great, is inexpensive, etc. I run about 30 - 35 psi rear, 5 psi front and this works well for me. I just checked my pressure last week for the first time in about 2 months and there had been no air loss. Pretty reliable system I think.
  • 1 month later...
Just the HD pump or one made like it. Zero air loss is the kicker not something you will get with a bicycle pump. The front forks take such a small volume of air if you try and check them with a gauge you will loose what air you have and will end up with and imbalance in your forks which may lead to handling problems. Better to have 0 psi up front till you have one of these pumps.
As I understand it, all H Dealers carry these pumps. I paid 48.95 plus tax I think.
They work great, as advertised !! No chance of blowing the seals.
Stopped at the Harley dealer 50.00 but they said they have a new generation digital one arriving soon for 10.00 more.
Save the $10 bucks and put $2 dollars with it and join up you will get a better return on your investment. Besides the gauge works just fine.
