Snaggletooth Posted July 17, 2012 #1 Posted July 17, 2012 (edited) Ok, before I hit the fleaBay curcuit again I know some of you are parting out some 1st gens. I find myself in need of at least one, if not both of the jointed mounting studs that tie the signal housings to the fender stays. I don't need the entire signal body, just the long angled stud that runs through it with the rubber joint and the short stud to the stay. But if the price is right for the whole assembly that will do to. Found why mine started wiggling so bad. The rubbers joints are breaking up. Let me know, Thanks, Mike Edited July 17, 2012 by Snaggletooth
friesman Posted July 17, 2012 #2 Posted July 17, 2012 Snaggletooth said: Found why mine started wiggling so bad. Let me know, Thanks, Mike ITs just because youre getting older...... Brian
Snaggletooth Posted July 17, 2012 Author #3 Posted July 17, 2012 I worry less about the wiggle than when it won't bend at all. Da' Snagglestud
Snaggletooth Posted July 17, 2012 Author #4 Posted July 17, 2012 I was able to grab a set off fleaBay for under $20.00. Should cover my parts needs. Thanks anyway. Mike
