hunter 1500 Posted July 14, 2012 Share #1 Posted July 14, 2012 I'm replacing the bolts in the brake disk and I'm not sure what grade they are but I purchased some SS bolts online and wondered if they would be alright. They are 18-8. Link to comment Share on other sites More sharing options...
Owen Posted July 14, 2012 Share #2 Posted July 14, 2012 I'm replacing the bolts in the brake disk and I'm not sure what grade they are but I purchased some SS bolts online and wondered if they would be alright. They are 18-8. Stainless Steel 18-8 falls in the '300' grade. Strength falls between grade 3 and grade 5. If the bolts you removed had 3 equally spaced lines on the head, they are grade 5 and the 18-8 stainless bolts are not as strong. If you really want to use stainless, find some '400's which will be closer to grade 5. Link to comment Share on other sites More sharing options...
Snarley Bill Posted July 14, 2012 Share #3 Posted July 14, 2012 if they are 400 they will be magnetic. if you are replacing the button head rotor bolts. why not use the original type bolts. they should be available from the dealer. Link to comment Share on other sites More sharing options...
hunter 1500 Posted July 14, 2012 Author Share #4 Posted July 14, 2012 if they are 400 they will be magnetic. if you are replacing the button head rotor bolts. why not use the original type bolts. they should be available from the dealer. Because I'm cheap and they are $4.79 apiece vs .45 each for SS. Just trying to save some money in hard times. Link to comment Share on other sites More sharing options...
hunter 1500 Posted July 14, 2012 Author Share #5 Posted July 14, 2012 Forgot to add that I need at least 8 of them. Link to comment Share on other sites More sharing options...
Snaggletooth Posted July 14, 2012 Share #6 Posted July 14, 2012 Because I'm cheap and they are $4.79 apiece vs .45 each for SS. Just trying to save some money in hard times.\ I'm not one to judge as I'm a frugal mechanic myself but I'm want to say there are times when cutting costs don't play in your favor. I'd be concerned to cut short on attaching the disks with weaker than needed bolts in this case. Mike Link to comment Share on other sites More sharing options...
Snarley Bill Posted July 15, 2012 Share #7 Posted July 15, 2012 Because I'm cheap and they are $4.79 apiece vs .45 each for SS. Just trying to save some money in hard times. check with www.mcmastercarr.com they carry metric button head bolts. don't know if they have stainless. Link to comment Share on other sites More sharing options...
