darthandy Posted July 2, 2012 Posted July 2, 2012 I was about to put some anti-squeak compound on the back of my front brake pads. I notice that the manual says 18 ft-bls of torque for the caliper retaining bolts. In the tech section there is a "service data" sheet that states 29 ft-lbs for the front brake caliper bolts. So... I'm assuming that the 29 ft-lbs is for the two bolts that attach the caliper "carrier" to the fork and the 18 ft-lbs is for the bolts holding the caliper to the "carrier". Can anyone verify that for me before I take things apart? Thanks. Andy
dingy Posted July 2, 2012 Posted July 2, 2012 I was about to put some anti-squeak compound on the back of my front brake pads. I notice that the manual says 18 ft-bls of torque for the caliper retaining bolts. In the tech section there is a "service data" sheet that states 29 ft-lbs for the front brake caliper bolts. So... I'm assuming that the 29 ft-lbs is for the two bolts that attach the caliper "carrier" to the fork and the 18 ft-lbs is for the bolts holding the caliper to the "carrier". Can anyone verify that for me before I take things apart? Thanks. Andy Which bike is the question about? 1st or 2nd gen? Gary
mm482 Posted July 2, 2012 Posted July 2, 2012 "So... I'm assuming that the 29 ft-lbs is for the two bolts that attach the caliper "carrier" to the fork and the 18 ft-lbs is for the bolts holding the caliper to the "carrier". Can anyone verify that for me before I take things apart? Thanks." You are correct. Earl
darthandy Posted July 2, 2012 Author Posted July 2, 2012 Oops - sorry Gary - it's my 2000 Venture. Thanks Earl - that seemed to make more sense to me, especially given the wording - but I hate to take chances with brakes. Not being able to stop can really take the fun out of a ride! Andy
