hipshot Posted January 16, 2008 #1 Posted January 16, 2008 i know i've seen it posted here, a dozen times, but does anyone know off the top of their head, what the part number is for a first gen carb diaphragm? i tried a simple search, and came up with nothing. maybe i used the wrong "phrase". just jt
Dano Posted January 16, 2008 #2 Posted January 16, 2008 Hip, this was on here last week, now it's about three pages back. Here's the part #: DIAPHRAGM ASSY (1FK-14940-09-00) (replaces 1FK-14940-00-00) Check Zanottis or Flatout for prices Good luck, Dan
hipshot Posted January 16, 2008 Author #3 Posted January 16, 2008 Hip, this was on here last week, now it's about three pages back. Here's the part #: DIAPHRAGM ASSY (1FK-14940-09-00) (replaces 1FK-14940-00-00) Check Zanottis or Flatout for prices Good luck, Dan MANY MANY thanks, dan. i intend to try and "cross match" this # with a"marine engine", number, at my local yami dealer. might be a lot cheaper, if it is the same part. ride safe and stay healthy . just jt
Marcarl Posted January 16, 2008 #4 Posted January 16, 2008 MANY MANY thanks, dan. i intend to try and "cross match" this # with a"marine engine", number, at my local yami dealer. might be a lot cheaper, if it is the same part. ride safe and stay healthy . just jt Let us know if it is cheaper, I'm going to need all four. Carl
Yammer Dan Posted January 16, 2008 #5 Posted January 16, 2008 Box I have in my hand is 41R-14940-09 These are 1st Gen
Yammer Dan Posted January 16, 2008 #6 Posted January 16, 2008 That is yamaha # without needle. Don't know if you can get them with needle but it is easy change from old one
Yammer Dan Posted January 16, 2008 #7 Posted January 16, 2008 Just be careful when you take needle out you don't loose little balland spring
Dano Posted January 16, 2008 #8 Posted January 16, 2008 Yeah, my box has 41R also. I think they told me 1FK was superceeded #. Same part, though. Dan
Squeeze Posted January 16, 2008 #9 Posted January 16, 2008 Yeah, my box has 41R also. I think they told me 1FK was superceeded #. Same part, though. Dan 41R is the Model which this Part was first time used. This Number doesn't matter much 1FK-14940-09-00 - '09' is the Number for a superceeded Part. 1FK is the first Vmax Model Number
