Ozlander Posted June 28, 2012 #1 Posted June 28, 2012 My turn signals have become cold blooded. They only work when it's above about 72* (not a problem right now) I'm assuming it's a sealed unit and no fixing possible. I believe the part no. is 41R-83350-71-00. Does anybody have a spare?
KIC Posted June 28, 2012 #2 Posted June 28, 2012 There are all sorts of unit looking things on my two 84 parts bikes. If I knew 1) if an 84 would work, 2) where it is located and 3) what it looks like I would be happy to send you one.
dingy Posted June 28, 2012 #3 Posted June 28, 2012 KIC said: There are all sorts of unit looking things on my two 84 parts bikes. If I knew 1) if an 84 would work, 2) where it is located and 3) what it looks like I would be happy to send you one. In the headlight housing area. About 2" x 4" x 3/4" Should have 41R printed on it. 10 wire connector, 9 wires used. Gary
KIC Posted June 29, 2012 #7 Posted June 29, 2012 I will try to get over to the bikes tomorrow to look. I have to finish a 3 1/2 hour online certification for a DSS Certification. When I finish that I can ride the heat wave over to the bikes.
Ozlander Posted June 29, 2012 Author #8 Posted June 29, 2012 KIC said: I will try to get over to the bikes tomorrow to look. I have to finish a 3 1/2 hour online certification for a DSS Certification. When I finish that I can ride the heat wave over to the bikes. I'm not in a real big hurry, like I say, it works when it's hot. Went out and looked for mine. Had to cut a nylon tie to lower the main harness that goes across the top of the head light opening to see it. It's in the top of the fairing about a half inch to the left of center as you're looking at the bike. It in a rubber holder and will pull out.
