RedRider Posted June 23, 2012 #1 Posted June 23, 2012 Which way does this spacer go on the rear wheel? This spacer goes against the rear wheel bearing and is the seal surface the seal rides against. There is a raised shoulder on one side while the other is flat. Pictures of both are attached. I am assuming the raised part goes against the bearing since it is the same diameter are the inner race. And yes, those are the balls from the rear wheel bearing. Not good. RR
DragonRider Posted June 23, 2012 #6 Posted June 23, 2012 You can get hurt that way..........................:bang head: Yammer Dan said: I was thinking....
Yammer Dan Posted June 24, 2012 #7 Posted June 24, 2012 DragonRider said: You can get hurt that way..........................:bang head: Just did enough to give me a headache.....
RedRider Posted June 24, 2012 Author #8 Posted June 24, 2012 I often do that too. Bought 12 spot muffin tins to keep nuts and bolts in with each opening labelled. The tins are teflon coated. Write what's in each hole with a sharpie. When done, a quick shot of brake cleaner and it all wipes clean. Just don't try to bake muffins with it afterwards. I've taken off the rear wheel so often I wasn't as careful as usual. In the end, I had it on right. Was just questioning it since the bearing went out. This was caused by something else (still investigating, but it wasn't this spacer). Just trying to cover all the bases. RR
Squeeze Posted June 24, 2012 #9 Posted June 24, 2012 A ruined Ball Bearing usualy is caused by tightening down the Axle without the Collar/inner Race on the left Side NEedle Bearing present.
