bikerjohn Posted June 19, 2012 #1 Posted June 19, 2012 Ok here the deal. Several times the bike has cut out like it is starving or out out of gas. One time I choked it and it started but when I tried to give it gas it bogged downand died. I leave it set for a while and it starts and runs fine. Today i brought it home and pulled the tank and the air boxes. First thing I noticed was oily stuff under the rail that holds the wires down. This is left side ONLY. Right looks nice and dry and clean. Oily and messy. I pulled the plug and it is clean and dry no signs of oil blowing by it. What do I need to look fo ras the cause I am going out to walmart to buy carb cleaner and clean it all up really good then keep a close eye on it. Any help would be great. It is a 2006 with about 40,000 on it.
steamer Posted June 19, 2012 #2 Posted June 19, 2012 Sea Foam Is the stuff u want to use. However, it sounds like a fuel feed problem. Whens the last time you changed the fuel filter?
bikerjohn Posted June 19, 2012 Author #3 Posted June 19, 2012 Thats what my nieghbor thought but why would it only effect the left side?
BuddyRich Posted June 19, 2012 #4 Posted June 19, 2012 If it starts and runs fine for a few minutes then you may have a fuel pump problem. Do you hear the pump clicking when you first turn the key on ?
bikerjohn Posted June 19, 2012 Author #5 Posted June 19, 2012 Yes i have heard it twice today but not every time I havent changed my filter I am doing that tonight!!
steamer Posted June 19, 2012 #6 Posted June 19, 2012 If its bogging and dieing you have a fuel problem. Its a problem with your filter or your fuel pump. Apperently the fuel pumps on these bike have been know to go bad. I would change the filter first, then check the pump.
V7Goose Posted June 19, 2012 #7 Posted June 19, 2012 Based on the very limited information here, I'd bet your fuel filter is clogged, or maybe the petcock intake screens. Could easily be a pump going south, but the fact that you have heard it several times in one day says it could just as easily be struggling to suck the gas as intermittently trying to pump. Your best test is to bypass the pump and run on gravity feed for a bit - if the fuel line and filter are good, it will run perfectly on anything over 1/4 tank of gas without a pump. Goose
bikerjohn Posted June 19, 2012 Author #8 Posted June 19, 2012 Thanks for the great info I just got a new filter and I am going to change it out.
darthandy Posted June 19, 2012 #9 Posted June 19, 2012 Small possibility but could the gas cap vent be blocked? If all else fails, you could try starting the bike with the gas cap open and seeing if it continues to run. Andy
bikerjohn Posted June 20, 2012 Author #10 Posted June 20, 2012 Well got the bike running let it run for 1/2 an hour and drove it a little. Think fuel filter was bad. as far as i know hasn't been replaced. I will see what happens. Thanks for all the help.
Rick Haywood Posted June 20, 2012 #11 Posted June 20, 2012 bikerjohn said: Thanks for the great info I just got a new filter and I am going to change it out. Is the oily stuff around the top of the carbs where the boots from the air box slides down over them? I had the same problem and found mine where coming loose and causing a little bits of gas to pop out at times. I actually found that the boots were turned around 180 degrees from the way they should have set in there. I turned them, cleaned everything up and the oily problem is gone.
